SDR-Overview (HackRF, rad1o, PlutoSDR, rtl-sdr, LimeSDR, AirSpy)
I've gone ahead and tested a couple of SDRs on the Pinebook Pro running Manjaro.
[Image: urgjpbyaqhk.jpg]
So far the AirSpy and HackRF are my clear favorites.
Here's my notes on what worked, what didn't and how to get it running:
HackRF / rad1o:
Very painless experience.
Just install (and run) gqrx via
sudo pacman -S gqrx
It'll depend on the HackRF driver.
To get it working without root-permissions create /etc/udev/rules.d/53-hackrf.rules.
sudo nano /etc/udev/rules.d/53-hackrf.rules
ATTR{idVendor}=="1d50", ATTR{idProduct}=="604b", SYMLINK+="hackrf-jawbreaker-%k", MODE="660", GROUP="plugdev"
ATTR{idVendor}=="1d50", ATTR{idProduct}=="6089", SYMLINK+="hackrf-one-%k", MODE="660", GROUP="plugdev"
ATTR{idVendor}=="1d50", ATTR{idProduct}=="cc15", SYMLINK+="rad1o-%k", MODE="660", GROUP="plugdev"
ATTR{idVendor}=="1fc9", ATTR{idProduct}=="000c", SYMLINK+="nxp-dfu-%k", MODE="660", GROUP="plugdev"
(save with Ctrl+O, Enter, Ctrl+X), then reboot.
[Image: ntsreobximc.jpg]
[Image: fotdunihyjq.jpg]
PlutoSDR:
Doesn't work! libiio segfaults at the moment (using software from 31.05.2020).
If you want to try yourself:
pacman -S soapyplutosdr
[Image: etqjronuxac.png]
RTL-SDR:
Works very well.
sudo pacman -S gqrx
[Image: yfvdnzahixl.jpg]
AirSpy (non-HF+):
Works very well.
sudo pacman -S gqrx
LimeSDR:
Didn't work with GQRX, worked with SDRAngel.
sudo pacman -S sdrangel-sse4.1 limesuite
[Image: jvytfkgedap.jpg]
Have fun,
Tobias
SDR-Overview (HackRF, rad1o, PlutoSDR, rtl-sdr, LimeSDR, AirSpy) - by manawyrm - 05-31-2020, 08:20 AM
