Newbie's first experience
I am new to the Pinebook Pro, but not Linux in general, and wanted to share some first thoughts on some tests I have made. Please note these are offered in the spirit of wanting to help, not as criticism. I am not in need of help to fix these things.
At first boot, I ran the updater. it shows 0 updates needed. This seemed unrealistic, so I ran sudo apt update in a terminal; it showed 90 updates available. I ran the updater again, but it still showed 0. I updated successfully anyway from the terminal.
Launching Chrome showed the Keyring request - potentially confusing for a newcomer?
I tried opening some standard testing files I use:
  • Graphics files opened in Nomacs as expected
  • Video files opened in SMPlayer, although there was a message warning the version of SMPlayer was out of date
  • A PDF file tried, but failed, to open in LibreOffice Draw; it seems there is no app for PDFs installed
  • MP3s open in SMPlayer, not RhythmBox. I was able to change that.
Using Caja, I tried browsing shares on my local network with the following problems:
  • Attempting to play video opened SMPlayer, but it crashed
  • Graphics files (PNG and JPG) tred to open Firefox, but failed. Forcing Nomacs works for the first image, but not subsequently
There appears to be no means to add a printer. Mine is connected to the local network. I got it working as follows:
  • Install system-config-printer
  • Install cups
  • From the run (Alt-F2) dialogue, run gksudo system-config-printer. (I subsequently modified the menu entry to run it as sudo)
This enabled the printer to be found and installed.
[*]Hope at least some of this might be of help.
Chris
@chrispop99, in regards to the updates. I too was confused. The non-Debian updater is for Pinebook Pro specific things like the kernel & boot support files. So it's possible you got the latest kernel. So it is reasonable to see what you saw.
The Chromium prompt for password saving annoyed me, so I disabled it. (I use a different method for saving passwords.)
I've added that Chrome prompt issue to the Wiki;
Wiki - Pinebook Pro - Chromium flags
As usual, feel free to correct, improve or comment, (good or politely bad).
Arwen Evenstar
Princess of Rivendale
(01-01-2020, 12:37 PM)Arwen Wrote: @chrispop99, in regards to the updates. I too was confused. The non-Debian updater is for Pinebook Pro specific things like the kernel & boot support files. So it's possible you got the latest kernel. So it is reasonable to see what you saw.
Good to know about the updater - thanks.
Chris
  Newbie Question!! oniichann 3 938 10-26-2023, 07:09 AM
  Newbie with immediate issue jasonumd 1 1,008 03-04-2023, 05:59 PM
Last Post: hacknix
  My Experience Using the Pinebook Pro as a Daily Driver warpnow 9 9,080 06-22-2021, 02:30 PM
Last Post: moonwalkers
  User experience quadrantids 14 12,446 03-26-2021, 05:06 PM
Last Post: dsimic
  Trackpad lack of fine movement and overrun ruining experience. gillham 25 28,620 02-03-2020, 01:14 PM
Last Post: bcnaz
  Help for a clueless newbie? breezy 3 4,739 01-06-2020, 07:07 AM
