USB 3.0 Host Controller crashes when accessing several devices simultaneously
(11-10-2018, 12:46 PM)lybin Wrote: Try add usbcore.autosuspend=-1 in /etc/default/extlinux and sudo update_extlinux.sh
Looks like a my problem not reproduced anymore and kernel doesn't crash.
[ 3966.656954] usb 10-3: reset SuperSpeed USB device number 3 using xhci_hcd
[ 3969.286859] usb 10-3: reset SuperSpeed USB device number 3 using xhci_hcd
[ 3971.284889] usb 10-3: reset SuperSpeed USB device number 3 using xhci_hcd
[ 3973.738677] usb 10-3: reset SuperSpeed USB device number 3 using xhci_hcd
[ 4007.029496] usb 10-3: reset SuperSpeed USB device number 3 using xhci_hcd
[ 4009.548435] xhci_hcd 0000:01:00.0: WARN Event TRB for slot 2 ep 2 with no TDs queued?
[ 4042.996762] usb 10-3: reset SuperSpeed USB device number 3 using xhci_hcd
[ 4045.515788] xhci_hcd 0000:01:00.0: WARN Event TRB for slot 2 ep 2 with no TDs queued?
[ 4079.018244] usb 10-3: reset SuperSpeed USB device number 3 using xhci_hcd
[ 4081.538333] xhci_hcd 0000:01:00.0: WARN Event TRB for slot 2 ep 2 with no TDs queued?
[ 4094.056556] EXT4-fs error (device sdf1): ext4_find_extent:910: inode #302082: comm scavenger: pblk 438336000 bad header/extent: invalid magic - magic f39, entries 17478, max 20872(0), depth 26550(0)
[ 4125.045784] usb 10-3: reset SuperSpeed USB device number 3 using xhci_hcd
[ 4158.064591] usb 10-3: reset SuperSpeed USB device number 3 using xhci_hcd
[ 4158.082063] xhci_hcd 0000:01:00.0: WARN Event TRB for slot 2 ep 2 with no TDs queued?
[ 4189.052740] usb 10-3: reset SuperSpeed USB device number 3 using xhci_hcd
[ 4222.070111] usb 10-3: reset SuperSpeed USB device number 3 using xhci_hcd
[ 4224.589439] sd 2:0:0:0: timing out command, waited 180s
[ 4224.590309] sd 2:0:0:0: [sde] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08
[ 4224.590339] sd 2:0:0:0: [sde] tag#0 Sense Key : 0x4 [current]
[ 4224.590365] sd 2:0:0:0: [sde] tag#0 ASC=0x40 <<vendor>>ASCQ=0x99
[ 4224.590396] sd 2:0:0:0: [sde] tag#0 CDB: opcode=0x88 88 00 00 00 00 00 d6 45 b1 e0 00 00 00 20 00 00
[ 4224.590417] blk_update_request: I/O error, dev sde, sector 3594891744
[ 4255.043288] usb 10-3: reset SuperSpeed USB device number 3 using xhci_hcd
Nov 09 16:08:15 rockpro64 kernel: usb 8-2: reset SuperSpeed USB device number 3 using xhci_hcd
Nov 09 16:08:17 rockpro64 kernel: xhci_hcd 0000:01:00.0: WARN Event TRB for slot 1 ep 2 with no TDs queued?
Nov 09 16:08:50 rockpro64 kernel: usb 8-2: reset SuperSpeed USB device number 3 using xhci_hcd
Nov 09 16:08:53 rockpro64 kernel: xhci_hcd 0000:01:00.0: WARN Event TRB for slot 1 ep 2 with no TDs queued?
Nov 09 16:09:06 rockpro64 kernel: EXT4-fs error (device sde1): ext4_find_extent:916: inode #302082: comm scavenger: pblk 851474688 bad header/extent: invalid magic - magic c19c, entries 4923, max 17809(0), depth 19583(0)
Nov 09 16:09:36 rockpro64 kernel: usb 8-2: reset SuperSpeed USB device number 3 using xhci_hcd
Nov 09 16:10:01 rockpro64 CRON[1399]: pam_unix(cronConfusedession): session opened for user root by (uid=0)
Nov 09 16:10:01 rockpro64 CRON[1400]: (root) CMD (/home/rock64/stat.sh | /home/rock64/ansi2html.sh > /var/www/html/index.html)
Nov 09 16:10:01 rockpro64 CRON[1399]: pam_unix(cronConfusedession): session closed for user root
Nov 09 16:10:10 rockpro64 kernel: usb 8-2: reset SuperSpeed USB device number 3 using xhci_hcd
Nov 09 16:10:10 rockpro64 kernel: xhci_hcd 0000:01:00.0: WARN Event TRB for slot 1 ep 2 with no TDs queued?
Nov 09 16:10:41 rockpro64 kernel: usb 8-2: reset SuperSpeed USB device number 3 using xhci_hcd
Nov 09 16:11:14 rockpro64 kernel: usb 8-2: reset SuperSpeed USB device number 3 using xhci_hcd
Nov 09 16:11:47 rockpro64 kernel: usb 8-2: reset SuperSpeed USB device number 3 using xhci_hcd
Nov 09 16:11:47 rockpro64 kernel: sd 2:0:0:0: timing out command, waited 180s
Nov 09 16:11:47 rockpro64 kernel: sd 2:0:0:0: [sdd] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00
Nov 09 16:11:47 rockpro64 kernel: sd 2:0:0:0: [sdd] tag#0 CDB: opcode=0x88 88 00 00 00 00 01 9d 99 11 e0 00 00 00 20 00 00
Nov 09 16:11:47 rockpro64 kernel: blk_update_request: I/O error, dev sdd, sector 6939021792
Nov 09 16:12:19 rockpro64 kernel: usb 8-2: reset SuperSpeed USB device number 3 using xhci_hcd
Nov 09 16:12:20 rockpro64 kernel: sd 2:0:0:1: [sde] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x05 driverbyte=0x00
Nov 09 16:12:20 rockpro64 kernel: sd 2:0:0:1: [sde] tag#0 CDB: opcode=0x8a 8a 00 00 00 00 00 00 00 08 00 00 00 00 08 00 00
Nov 09 16:12:20 rockpro64 kernel: blk_update_request: I/O error, dev sde, sector 2048
Nov 09 16:12:20 rockpro64 kernel: Buffer I/O error on dev sde1, logical block 0, lost sync page write
Nov 09 16:12:20 rockpro64 kernel: EXT4-fs error (device sde1): ext4_find_extent:916: inode #302082: comm scavenger: pblk 851474688 bad header/extent: invalid magic - magic c19c, entries 4923, max 17809(0), depth 19583(0)
Nov 09 16:12:20 rockpro64 kernel: EXT4-fs (sde1): previous I/O error to superblock detected
Nov 09 16:12:53 rockpro64 kernel: usb 8-2: reset SuperSpeed USB device number 3 using xhci_hcd
Nov 09 16:13:26 rockpro64 kernel: usb 8-2: reset SuperSpeed USB device number 3 using xhci_hcd
Nov 09 16:13:57 rockpro64 kernel: usb 8-2: reset SuperSpeed USB device number 3 using xhci_hcd
Nov 09 16:14:27 rockpro64 kernel: usb 8-2: reset SuperSpeed USB device number 3 using xhci_hcd
FYI the last post is 3 months old and this is the rock64 forum and you have a rockpro64 apparently, while the issue can exist on both boards i would be extremelly carefull...
  How Can Install Unify controller in rock64? gedas07 0 612 03-23-2020, 08:41 AM
Last Post: gedas07
  If installing free software system which devices will not work? heocb 6 2,389 08-17-2018, 09:42 AM
Last Post: heocb
  virtual machine, arm host kwarren 1 1,327 08-06-2018, 05:26 PM
Last Post: hiccupstix
  Im having weird crashes on a new rock64 [solved] Trash_Can_Man 4 3,039 02-06-2018, 04:06 AM
Last Post: a1w.ca
  Unifi Controller lightning 2 1,836 10-19-2017, 07:42 AM
Last Post: lightning
  My Board keeps crashing on startup, no USB devices conected Ptheven 0 690 09-19-2017, 10:29 AM
Last Post: Ptheven
