Added Arch Linux mainline with XFCE GUI [20171225-1] by anarsoul on PINE64 Installer
Arch Linux mainline XFCE
01-12-2018, 01:34 PM
Nice, more mainline for Pine64 \o/
With the scripts here https://github.com/anarsoul/linux-build/tree/mainline I probably can customize and create a minimal image right?
01-14-2018, 06:26 AM
(01-12-2018, 01:34 PM)douglasmiranda Wrote: Nice, more mainline for Pine64 \o/ Please do! Minimal install would be great, I ended up remove everything but base group and re-installing the pine64 specifics.
01-14-2018, 09:58 AM
(01-06-2018, 01:28 AM)pineadmin Wrote: Added Arch Linux mainline with XFCE GUI [20171225-1] by anarsoul on PINE64 Installer Works well for me although I can't figure out how to increase the resolution. The max in the Display Preference is 1024x768 but I was hoping for 1920x1080. I tried using xrandr and adding this resolution but that didn't work...
02-15-2018, 06:45 AM
Great to be on the mainline!
I seem to be having problems with the time changing on my pine now though ![]() Last week my date went back to 1970 with some time change and yesterday my date went to 2113. Not sure where to report these issues tbh.
02-16-2018, 08:29 AM
Check if the kernel you are using has the CONFIG_FSL_ERRATUM_A008585 enabled ...
02-18-2018, 12:54 PM
02-19-2018, 08:54 AM
I had that issue about a year ago with dates jumping in the 22th century, but since this CONFIG_FSL_ERRATUM_A008585 was added to kernel config, I've never seen the issue again ...
11-09-2018, 03:24 AM
Updated Arch Linux mainline XFCE (PINE A64(+)) 20181104 by anarsoul on Wiki and PINE64 Installer
02-14-2019, 05:56 PM
Long time arch user here, considering getting a rockpro64.
Is there a reason for having a custom package? Cant one just install plain archarm? Read above about some 'pine64' specifics - what are those? thanks |
what/where is the package manager on Arch Linux? | spruce1 | 9 | 14,588 |
04-03-2019, 05:58 AM Last Post: jose.ramirez |
Arch Linux image (BSP Kernel) | longsleep | 28 | 83,795 |
05-06-2016, 06:33 PM Last Post: tllim |
Arch Killing long running node/npm processes before finishing | faddah | 4 | 8,801 |
04-28-2016, 08:53 PM Last Post: patrickhwood |
