LibreELEC Krypton/Leia/Agile 64bit kernel 32bit libs
#71
It won't help it's a bug
(12-02-2017, 11:11 AM)Raybuntu Wrote: It won't help it's a bug
Is there any fix or am I SOL?
Not yet. DRM is still WIP.
What's the cause? Also, I'm surprised it's a DRM issue, it's just the UI, not the image actually flickering. I fail to see how HDCP would cause only the UI to flicker.
Where can I obtain the ROCK64 rb-krypton19 build? I can't find it in the list of releases at https://github.com/Raybuntu/LibreELEC.tv...-krypton19
I'm asking because I am getting the following error when I try to start a docker container with the rb-krypton18 build.
Quote:Error response from daemon: oci runtime error: container_linux.go:247: starting container process caused "process_linux.go:359: container init caused \"could not create session key: function not implemented\""
(12-03-2017, 05:20 AM)shockr Wrote: Where can I obtain the ROCK64 rb-krypton19 build? I can't find it in the list of releases at https://github.com/Raybuntu/LibreELEC.tv...-krypton19
There is no such release and there won't be any more Krypton based images. I'm focusing on Leia only now. Your Bug is resolved in the recent Leia builds.
@dawnbandit DRM = Direct rendering manager not the digital rights management DRM.
https://en.wikipedia.org/wiki/Direct_Rendering_Manager
(12-01-2017, 08:13 AM)Sauromayne Wrote: Makes sense lol. Has anybody else experienced this issue with stopping the video causing a crash and found a way to work around it?
Hello Sauromayne, i have the very same issue. Didnt find any way around it yet.
I will make a new build soon that will hopefully fix this.
https://github.com/Raybuntu/LibreELEC.tv.../rb-leia19
https://github.com/Raybuntu/LibreELEC.tv.../rb-leia20
New build. Please remember to update your addons. Kodi API changed so some addons may bet disabled by default on first boot. You need to install updates from my repo and re-enable
 those disabled binary addons (inputstream.adaptive).
RetroPlayer works very well now on ROCK64. To enable games menu to you need to input a Konami code at Home Screen:
Up Up Down Down left right left right b a
Video Playback was improved too.
  Libreelec nfs shares nberg@xs4all.nl 0 667 11-11-2022, 01:18 PM
Last Post: nberg@xs4all.nl
  Linux 5.15 Kernel - openSuse mark1250 0 1,295 12-02-2021, 04:36 PM
Last Post: mark1250
  Security Patches for the Kernel kwinz 9 6,799 10-22-2021, 05:45 AM
Last Post: kwinz
  Debian kernel stuck at 4.4.167 Enig123 5 5,663 12-29-2020, 12:57 PM
Last Post: kwinz
  Arch Linux Arm --> Kernel 5.8 breaks installation as365n4 12 12,338 08-31-2020, 01:41 AM
Last Post: as365n4
  mainline kernel sound support Openwrt lucize 2 4,084 05-01-2020, 05:09 PM
Last Post: PakoSt
  5.3 kernel support? csrf 5 7,122 04-18-2020, 11:34 PM
Last Post: CameronNemo
  Help troubleshooting kernel panic gabrielfin 3 4,659 03-02-2020, 04:18 PM
Last Post: gabrielfin
  need a dts file to set some pins as pulldown interrupts in kernel using a DTO dkebler 0 2,028 02-05-2020, 10:58 PM
Last Post: dkebler
  Any advantages to using the mainline kernel dkebler 0 2,131 11-16-2019, 12:17 PM
Last Post: dkebler
