PinePhone Pro EDL boot by shorting contacts
Hello!
I am a new PinePhone user and I recently purchased a PinePhone pro explorer edition. After installing Tow Boot and trying several distributions, I was unable to get voice calling to work. As a result, I attempted to update the modem firmware, thinking that this may be the issue (after no issues with microphone or other audio systems were apparent anywhere). The modem appears to never have booted up properly again, and now the modem is not recognized by the operating system at all.
The reason for this post is because I cannot find the EDL boot test points on the motherboard that are mentioned in several different places (GitHub - Biktorgj/quectel_eg25_recovery: Stock firmware recovery packages for Quectel EG25-G, pinephone_modem_sdk/docs/RECOVERY.md at kirkstone · the-modem-distro/pinephone_modem_sdk · GitHub, https://forum.pine64.org/attachment.php?aid=2843, ...).  The motherboard in my phone does not have these contacts (text on board: "Pinephonepro-V02 2023-0909"). In fact, there is a metal shield attached to the board directly over that area. Is there any way to access these contacts on Pinephone pro explorer edition boards like version 2023-0909?
Thanks for any help!
I hope this can send you in the right direction: https://fosstodon.org/@biktorgj/111865670770893789
(04-30-2024, 12:30 PM)ozkenlc Wrote: Hello!
I have the same hardware version. I managed to boot into EDL and flash stock firmware. You need to short T6504 with T6503. Unfortunately T6503 is on slightly different place that in the schematics. More to the right. Find a point that is not in the schematics.
Schematics:
https://files.pine64.org/doc/PinePhonePr...bottom.pdf
Approximate place:
https://pasteboard.co/B66sOa46PgH0.png
  Pinephone pro shuts down immediately after login covar 4 298 07-03-2024, 10:59 AM
Last Post: covar
Thumbs Up Pinephone Pro + Keyboard for sale Jimmy88 2 1,094 04-22-2024, 08:38 PM
Last Post: AegisWages
  PinePhone only turns on sometimes zvavybir 1 604 03-27-2024, 12:19 PM
Last Post: zvavybir
  PinePhone Pro Explorer's edition Qualcomm modem recovery shifras 7 1,934 03-24-2024, 02:22 PM
Last Post: zetabeta
Question Screen turning off and booting problems with the Pinephone Pro xnZwJR6vys9a2wm7yWE4 0 373 01-16-2024, 02:38 PM
Last Post: xnZwJR6vys9a2wm7yWE4
  Pinephone Pro LCD and Touchscreen Hobgoblin 8 4,469 01-14-2024, 02:50 PM
Last Post: shifras
  Recurrent problems with broken charger chip on the pinephone/pinephone pro keyboard Jite 4 1,552 11-18-2023, 07:25 AM
Last Post: crocspot
  is it possible to install a pinephone pro mainboard in a pinephone hannescam 7 3,264 08-13-2023, 04:50 AM
Last Post: fxc
  Pinephone pro packet injection for internal wifi chipset covar 1 1,038 08-13-2023, 04:40 AM
Last Post: fxc
  PinePhone Keyboard won't work. read_kb_reg(PPKB_SYS_CONFIG) needs what? jovval 0 624 07-09-2023, 09:03 PM
Last Post: jovval
