Victron Energy on PinePhone Pro
Does anyone know if the app from Victron Energy works on the PinePhone Pro?
Victron makes devices for solar energy and the app connects to their devices and their database of daily statistics.
It is generally safe to assume that Android or iOS apps do not work. Android apps may or may not work under Waydroid, and if they run, their functionality may or may not be limited. But they will not run natively on the system. iOS apps will not run at all.
I see that they have a Linux image.
https://www.victronenergy.com/support-an...s/software
Thank you!
Unfortunately, that AppImage is almost certainly built for x86_64 and will not run on aarch64 (64-bit ARM), at least not without using really slow software CPU emulation.
(04-19-2023, 12:43 AM)Kevin Kofler Wrote: Unfortunately, that AppImage is almost certainly built for x86_64 and will not run on aarch64 (64-bit ARM), at least not without using really slow software CPU emulation.
That is unfortunate, but thank you.
  Pinephone pro replacement lcd screen Linuxuser3 0 244 04-27-2024, 05:42 AM
Last Post: Linuxuser3
Question Pinephone Pro for a Debian user? primesocial 2 329 04-15-2024, 03:01 AM
Last Post: zetabeta
  PinePhone Pro silver lining, it’s fast, real damn fast ashoka232 0 617 03-20-2024, 01:45 AM
Last Post: ashoka232
  PinePhone Pro Black Screen CrimsenRaven 2 518 03-16-2024, 11:40 AM
Last Post: tmoj
  PinePhone Pro Review tmoj 2 933 03-14-2024, 07:14 AM
Last Post: tmoj
  Can't boot Pinephone Pro into Factory Test Build for Hardware Checking jydoxcen 3 848 02-17-2024, 04:04 AM
Last Post: fxc
Question Phone call with the pinephone pro dfs 5 4,460 02-10-2024, 09:54 PM
  Average Joe review of Pinephone Pro (March 2023) alaraajavamma 6 10,712 01-06-2024, 11:32 AM
Last Post: mikehenson
Question T-Mobile and Pinephone Pro in the US jydoxcen 4 1,003 01-02-2024, 09:08 AM
  Pinephone Pro Screen Protector jydoxcen 11 1,689 12-21-2023, 07:58 AM
Last Post: zetabeta
