PPkeyboard oddities with top row characters on "dreemurrs-embedded / Pine64-Arch"
So I recently installed arch https://github.com/dreemurrs-embedded/Pi...g/20230203 on on my Pinephone (not pro), and tried to use the keyboard which was fine except the top row characters ( - _ + = ~ etc), I don't know exactly what i did but it fixed it for me.
I updated my ppkb's firmware to 1.3 here's the guide to update https://xnux.eu/log/#078
I then used the bottom part of this guide https://wiki.mobian-project.org/doku.php...ccessories this part:
Symbol Keys
With the latest version of the keyboard drivers, the Fn-symbol keys disappear. This can be fixed by:
  • Setting
    XKB_DEFAULT_MODEL=ppkb
    in Phosh's environment. Add the following to
    /usr/lib/systemd/system/phosh.service.d/override.conf
[Service]
Environment=XKB_DEFAULT_MODEL=ppkb
  • Reboot or restart Phosh.
After this, the top row symbols will be available as L3-{0-9}. The L3 key can be configured in settings → keyboard → Alternative Characters Key.
New versions of Mobian do not launch Phosh as a systemd service. In that case the override above will not work. Instead, add the following line to
~/.profile
export XKB_DEFAULT_MODEL=ppkb
and reboot.
I then went to (phosh) settings -> keyboard -> special character Entry -> Alternate Characters Key: and changed it to left alt
it then worked,
and it continued to work when I changed it back to the original alternate character key.
Hope this helps someone out there! Smile
Thanks for posting! I did find your post useful.
  Shout Out to Pine64 and Terminal_Heat_Sink drh 0 944 03-26-2023, 02:54 AM
Last Post: drh
  pine64 keyboard pogo 'no-go' pins --- 3 2,583 04-29-2022, 04:59 AM
Last Post: Humid Stylus
  What Pine64 do I own? jwhitmor 5 3,334 12-31-2021, 08:49 AM
Last Post: ryo
  SDR pine64 Manjaro Desodo 8 6,858 01-18-2021, 09:54 AM
Last Post: dsimic
  Endless crashes on Pine64 received today luciphercolors 4 5,639 11-24-2020, 06:09 PM
Last Post: rocket2nfinity
