Microphone on Hardware Model 1.2 is Unusably Noisy In Some Circomstances
I should start by saying I have found a way to temporarily fix the issue on my pinephone, but hopefully this will be useful for others regardless.
I received my pinephone roughly 7 months prier to this post, and while I was enjoying and getting good use out of the device, the microphone started having random bouts of noise & static to the point that it was unusable, no matter what distro was installed. after taking the phone partially apart, I narrowed the issue down to physical pressure on the microphone mounted to the daughter board. It seems that almost anything that puts pressure on the microphone can cause or fix this issue, namely whether or not the battery is installed, charged, expanding, contracting, how tightly the three screws holding in the daughter board are tightened, whether the backplate or case is installed, etc. Even putting a piece of duct tape in between the battery and the plastic holding in the daughter board can cause the mic to be unusable.
This issue strikes me as one that could be inadvertently be the cause of many bug reports to distro & modem firmware maintainers, as I haven't seen anyone online having this sort of issue, so hopefully this post can clear this up.
The next steps for dealing with this issue are probably a small note about it in the wiki and dealing with it on a hardware level for future revisions, as I think end users would find the microphone being unusable half the time to be unacceptable for a released smartphone. I should also point out that I can only confirm this issue effects the Pine64 PinePhone (1.2) Hardware Model, so comment below if you can reproduce the issue in older revisions or the pinephone pro.
(01-04-2022, 05:36 PM)ASmartSuitedSimpleton Wrote: I should start by saying I have found a way to temporarily fix the issue on my pinephone, but hopefully this will be useful for others regardless.
I've got the 1.2a revision Pinphone (Postmarket OS, convergence edition). I'm not sure if I'm affected by this, but I did have complains about audio call quality, and people heard their echo even with the speaker set to very low volume (but when I lower it even further, to the point I can't really hear the person at the other end of the call, there is no echo anymore, so it seems to be a microphone / speaker issue)
You said you had found a temporary fix, what did you do ?
The only things that seems to work (occasionally) are some percussive maintenance to the bottom of the device, pinching between the screen & backplate with the microphone hole in between, or other kinds of adjustments. Even then, the microphone could start or stop working basically at random.
@ASmartSuitedSimpleton
The only "Microphone Problem" I have encountered was when I was using the 'speaker phone' function.
I found simply turning down the 'microphone volume' (settings---> sound) ... seems to have solved that problem for me, and my callers.
Cheers
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
I've also had issues with my mic, (bought my pinephone in 2022) usually it is dead silent... occasionally I will barely hear static if I replay recorded audio and put my ear up to the speakers. if I find a way to fix this I'll post something here
  Is the hardware still being developed and refined? orbital 10 4,998 09-01-2022, 08:05 PM
Last Post: orbital
  Need a new microphone? kujo_marble 0 759 08-16-2022, 08:26 PM
Last Post: kujo_marble
  Microphone replacement SocialNetworkingWasAMistake 1 1,548 08-05-2022, 03:16 PM
Last Post: calinb
  How to check hardware revision? jojuma 1 1,593 07-16-2022, 12:28 AM
Last Post: bokomaru
  Modem Hardware bad? Not ready for 5g?? linux76 8 4,715 05-31-2022, 06:41 PM
Last Post: SwordfishII
  Any experiences with hardware mod to improve eMMC speeds? kqlnut 9 5,968 04-19-2022, 02:36 PM
Last Post: kk22
  Dead Microphone? Pulsar 4 3,810 02-16-2022, 12:58 PM
Last Post: mysociallife
  Hardware switch for mic is not working properly submariner 10 7,677 01-25-2022, 07:01 AM
Last Post: wibble
  No Connection to Carrier from Pinephone 3G Model nonoreply 2 1,524 10-17-2021, 06:29 AM
Last Post: wibble
  Case hardware request/idea HobanWashburn 5 4,505 09-15-2021, 04:02 AM
