RTL8811AU usb wifi for pbpro
Hello Everyone,
I had a TP-Link AC600 T2U Nano  (chipset REALTEK RTL8811AU) wifi usb dongle laying around and I wanted to use it with my PineBook Pro to improve a bit my wifi.
After a bit of time looking around I managed to find a solution to make it work  so I decided to share the solution I found.
I will start by saying three things:
1: to anyone wanting to buy a USB WIFI dongle for use with any kind of linux device I would advise to read https://github.com/morrownr/USB-WiFi . In particular I would advise  AGAINST buying a usb wifi dongle that has a REALTEK chipset.
2: this is my first post on this forum, maybe I am doing it wrong but please be gentle.
3: this solution is very similar to https://forum.pine64.org/showthread.php?tid=14767 (which concerns a similar chipset : the RTL8812AU).
Solution:
Get the driver from https://github.com/morrownr/8821au-20210708
Follow instructions 1 to 7 from the README
Before executing #sudo ./install_driver.sh modify the Makefile as follows:
find the lines
SUBARCH := $(shell uname -m | sed -e s/i.86/i386/)
ARCH ?= $(SUBARCH)
 and replace them with
# ARCH ?= $(SUBARCH)
ARCH := 'arm64'
As explained in https://forum.pine64.org/showthread.php?tid=14767 for a similar driver, this modification is necessary because otherwise the architecture is detected as 'aarch64' and the Makefile does not recognise this architecture.
Then run
I had no errors and after a reboot my USB wifi was recognised and fully functionnal.
I hope this might help someone someday.
Note: this should work for similar wifi chipsets by replacing the driver https://github.com/morrownr/8821au-20210708 by the relevant one in https://github.com/morrownr .
  Kernel Not Detecting Wifi tallfrye 10 6,157 01-01-2024, 06:57 AM
  PBPro Battery specification Perl6_user 3 3,562 12-26-2023, 04:28 PM
Last Post: DrYak
  Connection to WiFi with OWE IhorOlkhovskyi 1 3,086 09-01-2022, 08:48 AM
Last Post: IhorOlkhovskyi
  Is there a way to turn off Wifi completely? jirow 10 15,262 06-20-2022, 05:53 AM
Last Post: Kaythe
  Mini-Howto: ROCK64 USB 3.0 WIFI Adapter (Rabbit-ear) on Manjaro Dendrocalamus64 1 4,675 11-14-2021, 03:41 PM
Last Post: Dendrocalamus64
  Wifi disconnecting after few minutes hellojack 0 2,468 09-16-2021, 02:50 AM
Last Post: hellojack
  Advice on increasing WIFI range stozi 2 6,232 03-29-2021, 06:57 AM
Last Post: barray
  Curious about problem with PBP Wifi kendew 3 7,206 01-14-2021, 11:16 AM
Last Post: clover
  Privacy switches - cutting power to wifi card as400 1 4,425 08-10-2020, 09:48 AM
Last Post: belfastraven
  Soldering internal Wifi/Bluetooth antenna petet0n76 1 5,374 06-20-2020, 12:01 PM
