PinePhone Keyboard: Space as modifier
Since about ten years, I run TouchCursor on my PC. It turns Space into a modifier:
  • Space down, i down: equivalent to
  • Space down, j down: equivalent to
  • Space down, u down: equivalent to Home
  • Space down, y down: equivalent to PgUp
  • Space down, Space up: regular space
The big advantage is that my hands don’t need to change position. I don’t use the cursor keys any more. Furthermore, with Space as modifier, I can just press it with the thumb on my right hand. Then I have my left hand to press all the other modifiers: Ctrl, Alt, Shift
Will I be able to configure the PinePhone keyboard to behave in the same way?
I think yes because any two keys can be used in combination judging from what the developer behind the firmware noted.
See: https://xnux.eu/log/#043
(10-03-2021, 05:36 AM)lot378 Wrote: I think yes because any two keys can be used in combination judging from what the developer behind the firmware noted.
Thanks! That's indeed crucial, if I want to enable TouchCursor functionality under X or Wayland. I hope this is possible, but it should. On my PC I use Windows with Linux in a VM, and TouchCursor runs on Windows.
I wonder: Will users be able to modify the firmware? Then I could hard code those key combinations.
It certainly looks like that's the intention. See https://xnux.eu/log/#044 for the later report, including links to the firmware source. Towards the end of the first set of bullet points there's discussion of the approach to flashing via i2c so users don't need to solder a USB connection, and the split between stock and user firmware.
(10-05-2021, 03:57 AM)wibble Wrote: It certainly looks like that's the intention. See https://xnux.eu/log/#044 for the later report, including links to the firmware source. Towards the end of the first set of bullet points there's discussion of the approach to flashing via i2c so users don't need to solder a USB connection, and the split between stock and user firmware.
Very cool, and thanks for the link!
I am currently running Mobian. I have found that by hitting the globe key and choosing terminal the left/right up/down keys will appear at the top of the keyboard along with ctrl and alt. So now you can move the cursor all around in your document. Hope this helps.
Thanks for the suggestion. However, I think you are referring to an on-screen keyboard, while we're discussing the hardware keyboard here.
(01-04-2022, 03:52 AM)feklee Wrote: Thanks for the suggestion. However, I think you are referring to an on-screen keyboard, while we're discussing the hardware keyboard here.
Sorry for the confusion. I have been using an external bluetooth keyboard from Amazon that has a touchpad with left/right mouse buttons. Makes navigation on the pinephone much easier.
  Case for Pinephone totilele 13 7,674 04-11-2024, 11:48 AM
Last Post: gramonyl
  keyboard case charging but not typing new2pinephone 18 6,046 02-19-2024, 07:30 AM
Last Post: theResonant
  Keyboard doesn't charge my phone no matter what, so can I charge my phone directly ragreenburg 3 11,095 01-14-2024, 03:34 PM
Last Post: acid andy
  PinePhone Dock with laptop? Mikey1977Y2J 2 681 12-12-2023, 05:43 PM
Last Post: Mikey1977Y2J
  I've added an I2C connector to the PP keyboard eugenr 0 458 11-26-2023, 07:24 AM
Last Post: eugenr
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 8,313 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 481 10-22-2023, 03:39 PM
Last Post: rotwang
Exclamation USB mouse isn't working when a PP keyboard is attached? mikeb 3 1,308 10-21-2023, 08:21 PM
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 552 10-21-2023, 07:50 AM
  Which mini keyboard and mouse to choose for the PP? Peter Gamma 0 649 10-21-2023, 02:55 AM
