Battery mot charging past 54%
#31
(01-14-2022, 08:29 AM)kqlnut Wrote:
(01-14-2022, 04:49 AM)vusra Wrote: It charges to 100%, then it discharges to 93 - 95%... then charges again to 100% ... repeat... sounds bad for the battery left on the charger long term. Can a maximum charge limit be set?
See megous' comment a couple of posts before for an explanation. And yes, a maximum limit can be set and is set already on many distros (what is displayed in the battery indicator as 100% may not be the real 100% capacity the battery has). Check out the PostmarketOS tweaks app for a GUI to change that (not only available on PostmarketOS).
PostmarketOS tweaks  battery limit setting does not work in Debian.  The setting change returns to 4.20V after opening PostmarketOS tweaks again.
What you are describing is the normal float charge pattern, to hold the phone near 100%
Some of the distributions are adding apps that allow the user to easily adjust their own charging patterns.
I don't think This is harming my battery,  ...
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
PostmarketOS tweaks in mobian offers changing the maximum charge level. It is not functioning. The setting change returns to 90% 4.20V after opening PostmarketOS tweaks again.
  Battery connector dead mdk 5 3,029 01-15-2026, 02:24 PM
Last Post: mikeb
  Battery Life- hardware abstraction layer-GPU VS optomizing app for GPU-openGL biketool 1 2,451 09-20-2024, 04:04 AM
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 4,135 02-17-2024, 04:15 PM
Last Post: vortex
  Battery life improvement freelectro 10 9,757 06-01-2023, 08:27 PM
Thumbs Down Battery Issue or Power Management IC? bcoyle 2 4,380 03-20-2023, 12:54 AM
Last Post: bcoyle
  Charging Indicator On - Not Charging SJSEng 0 1,836 08-30-2022, 07:33 AM
Last Post: SJSEng
  Power supply vs battery albafrati 11 10,736 06-22-2022, 06:04 PM
Last Post: albafrati
  PPKB with phone; phone dies while charging SwordfishII 1 3,244 06-08-2022, 04:14 AM
Last Post: SwordfishII
  What PD charger/dock combo results in PP battery not draining while using convergence james8880 0 3,177 04-28-2022, 12:45 PM
Last Post: james8880
  Screen has pixel-thin horizontal stripes that are black or get stuck in the past yasmi 5 7,686 03-08-2022, 12:25 PM
Last Post: jopple
