Is the PinePhone compatible with UHS-II or UHS-I Micro SD?
Just wondering is it worth buying a faster Micro SD card for a PinePhone Community Edition so it may run a bit faster?
The quicker cards tend to be USH-III then USH-II then USH-I:
https://www.androidcentral.com/best-micr...rd-android
If your device is only capable of dealing with USH-I devices then if you plug in a USH-II device then it will run at USH-I speeds.
https://havecamerawilltravel.com/photogr...osd-cards/
Here it says that for the Rock64 it probably supports USH-I but not any higher:
https://forum.pine64.org/showthread.php?tid=4685
The user manual says UHS1.
I can confirm the Samsung EVO Select 128GB microSDXC UHS-I U3 works perfectly in my postmarketOS Community Edition with the convergence package. Everything I've tried so far feels quite snappy for an SD card. I would recommend going no lower than 128GB, though, as the product description states:
Quote:¹4K UHD video support for 51GB, 256GB and 128GB cards.
I imagine "51GB" should be "512GB".
(09-19-2020, 08:18 AM)5432h90asfd Wrote: Just wondering is it worth buying a faster Micro SD card for a PinePhone Community Edition so it may run a bit faster?
See this post and this comparison then buy a saumsung evo plus card.
Really helpful. Muchas Grascias.
Note that Samsung Evo+ and Samsung Evo Plus are two different cards. The Evo+ is no longer manufactured, and the Evo Plus is not as good at random IOPS (around 60-75 % of the performance of the Evo+; see this comparison)
An alternative that looks good is "SanDisk Extreme 100MB/s UHS-I U3 V30 A1 32GB microSDHC" (SDSQXAF-032G-GN6MA), see this review.
  my pinephone melted norayr 6 909 04-04-2024, 07:22 PM
  Pinephone refusing to charge while suspended tiol 1 1,095 04-02-2024, 10:54 AM
Last Post: joH_N_Doe64
  various tricks to open the pinephone shengchieh 2 721 03-23-2024, 09:27 AM
Last Post: Ferriah
  pinephone can provide more than 500mA to a usb-c displayport device? unrznbl 2 354 03-21-2024, 08:52 AM
Last Post: unrznbl
  pinephone keyboard + dock question tuxcall 7 2,846 02-05-2024, 03:17 PM
Last Post: wigan
  Unsatisfactory GPS reception on PinePhone? LinAdmin2 53 56,008 12-17-2023, 11:42 AM
Last Post: robin.com.au
  PinePhone Pro not booting (Cap error!, pctl timeout) jealda 2 1,404 11-16-2023, 05:03 AM
Last Post: DrYak
  Pinephone frame damages Uturn 2 1,004 10-23-2023, 02:49 AM
Last Post: Uturn
  PinePhone Keyboard KJ6OHG 11 8,159 08-23-2023, 03:25 AM
Last Post: Kali
  PinePhone constantly vibrating and won't take charge ImmyChan 5 5,463 07-23-2023, 03:49 PM
Last Post: kb-zealot
