Mobian and WiFi
Hi - I am a very new owner of a pinephone and have been trying Mobian.  I have not installed a sim card and I am running Mobian from an SD.  I can connect to home WiFi and the UI is easy to understand and use.  My trouble is that apps seem not to be able to use the WiFi.  For example neither browser can connect to any website and Geary can not connect to email servers.  It seems as if there is some setting that I am missing or that a sim card is required.I have checked the Mobian gitlab issues and have found nothing. Any insight? Regards and thanks.
Make sure battery fully charged otherwise wifi connection will be difficult. Used to work fine up to a nearly dead battery on an earlier software version.
I have the Pinephone UBports CE. I'm running Mobian (nightly from 2020-08-17 if I'm not mistaken) from SD card and my WiFi is working fine. I don't have a SIM card in my phone.
So I'm not sure what can be causing your issue. Maybe you could run "King's Cross" (Mobian's terminal program) and ping your router and some external server, and use 'host' to check that DNS is working? The results should give a clue as to where the problem lies.
First, thanks for the replies and suggestions!
Today I started from a completely off state.  After a bit, the wifi kicked in and apps were able to use it.  So, now I am off to try various apps.
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 16 2,025 3 hours ago
Last Post: zetabeta
  Mobian repository status henrythemouse 16 8,769 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 133 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,006 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,831 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 634 09-01-2023, 11:29 AM
Last Post: Mahgue
  reset wifi hardware/driver when it dies through console on pp? tuxcall 4 1,888 07-18-2023, 08:54 AM
Last Post: junelung
  how to update mobian over tor vusra 13 6,919 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,905 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 634 07-05-2023, 03:57 AM
Last Post: paulcarton
