Is there a way to pull up the terminal in Remix so I can check what is going on with my USB Wifi device. I cannot get any android image to recognize it.
(05-19-2016, 01:12 PM)jpecora93 Wrote: Is there a way to pull up the terminal in Remix so I can check what is going on with my USB Wifi device. I cannot get any android image to recognize it.
Remix OS based from Android build and I don't think USB Wifi device has been supported,
There's terminal apps in the play store that use busybox to get a terminal and standard tools.
However for USB device, I would think that it would depend of the kernel.
