Installing Mobian --> "Resizing file system" forever
(03-22-2021, 03:42 PM)Anna Wrote: To install Mobian on an SD card I, all I theoretically have to do is to download mobian-pinephone-phosh-20210314.img.gz, write it to the card, put the card into the phone and start it, right?
However, when I do that, the "resizing file system during initial boot" screen is there for quite a long time (30 minutes maybe) and afterwards the screen turns black (not pitch black though, the display remains switched on) and that's it.
I have used two different 64 GB cards  (a new Sandisk Extreme and and old Sandisk Ultra). I used BalenaEtcher and I tried
sudo zcat mobian-pinephone-phosh-20210314.img.gz | sudo dd of=/dev/mmcblk0 bs=1M
What am I doing wrong? Huh
If you are using Balena Etcher :
      You do not SUDO  anything.
You simply download Mobian,  then use Balena Etcher to flash your sd card.
<(You Can prep your sd card,   IF   you so desire,  format or zero wipe or whatever)>
I have been using Balena Etcher and Mobian since the first release of Mobian.
   * (actually that's all I have ever used,  -  since I purchased my first Pinebook Pro, from the first public sales,  second batch I think, Sept. 2019)
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
(08-31-2021, 11:59 PM)bcnaz Wrote: If you are using Balena Etcher :
Thanks! Sorry if I did not express myself clearly: I had tried "sudo zcat..." and, after that attempt failed, I tried Balena Etcher, both several times.
The solution was @dukla2000 's answer.
our Pinephone arrived about a week ago and I had the "resizing forever" issue with mobian-pinephone-phosh-2021051 yesterday. My solution was to resize it manually before inserting the SD into the computer.
Just wanted to say that the filesystem is f2fs, not ext2 as described in the Installation Instructions
For me, these commands worked:
: sudo bmaptool copy --bmap Downloads/mobian-pinephone-phosh-20210517.img.bmap Downloads/mobian-pinephone-phosh-20210517.img.gz /dev/mmcblk0 : sudo growpart /dev/mmcblk0 2 : sudo resize.f2fs /dev/mmcblk0p2
(09-09-2021, 02:42 AM)loderunner Wrote: Just wanted to say that the filesystem is f2fs, not ext2 as described in the Installation Instructions
Just wanted to say, that these are not the installation instructions for mobian which has it's own.
  Printing from Mobian johnd 3 5,245 10-27-2026, 06:01 AM
Last Post: PrinterSolvedTeam
  Mobian MMS/SMS text problem bcnaz 16 41,291 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 2,200 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 72,922 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 75,840 10-08-2025, 06:21 AM
  XLibre for Mobian Hiraghm 0 3,688 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 361,297 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 3,367 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 4,654 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 5,383 05-06-2025, 02:19 AM
