DAC (ES9023) addon card on other SBCs like rpi?
Not sure it's correct to ask about other boards here, but may be someone has tried this DAC addon card from rock64 on other single board computers like raspberry for example?
I have an rpi4 and wonder if this DAC can be used with it.
If you mean the PINE A64 stereo dac board, then no, that most likely won't work on other SBCs "out of the box". Since it does communicate using standard protocols though, you can manually wire yourself up an adapter for the used pins, specifically the SPI and SPDIF pins as well as power/ground, but that'll be a very flimsy solution.
Occasional Linux Kernel Contributor, Avid Wiki Updater, Ask Me About Quartz64
Open Hardware Quartz64 Model A TOSLink Adapter
Pi-bus GPIO Extender For ROCKPro64 And Quartz64 Model A
Plebian GNU/Linux
  How to enable ES9023-based DAC hat on Rock64? lowry 2 6,011 03-18-2021, 03:44 PM
Last Post: zborgerd
Question Have eMMC adapter - but can't seem to fix eMMC card SirRyanTheGeek 3 11,935 05-04-2019, 04:19 AM
Last Post: burito111
  can a SD card be used as storage with emmc boot Enzo 9 22,601 05-10-2018, 08:53 PM
Last Post: pfeerick
  Flashing full image to eMMc with a mSD card to eCMM adapter pytheas 2 6,602 04-09-2018, 03:56 AM
Last Post: Luke
