Bleachbit on Mobian
Bleachbit : from the Mobian onboard software store installs both user and root in just one install.
  However only the user part part will open and work.?
 Is there an easy work around,  or just wait for the developers to get it working ?
Sent from my PMOS phone, August 22 Mobian/Bookworm Nightly on sd card, PureTalk cell/Data
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
I wonder if Bleachbit can be used safely with Mobians f2fs file system ?
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
Well...
I see Mobian has moved from f2fs to ext4...
I do wonder if they will return to the f2fs later, or what..?
Will Bleachbit as 'root' eventually work on Mobian ? ( as 'user' is only a part of the app. that currently works)
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
(01-06-2022, 08:58 PM)bcnaz Wrote: Well...
With the mobian installer you can choose between f2fs and ext4..
(08-23-2021, 05:49 AM)bcnaz Wrote: Bleachbit : from the Mobian onboard software store installs both user and root in just one install.
Problem is bigger than bleachbit. Many GUI software do not run with root privileges.   In the past gksudo was available to run GUI software as root. Example https://forum.pine64.org/showthread.php?tid=14469 Who has solution?
  Printing from Mobian johnd 3 5,085 10-27-2026, 06:01 AM
Last Post: PrinterSolvedTeam
  Mobian MMS/SMS text problem bcnaz 16 40,958 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 2,073 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 71,566 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 75,183 10-08-2025, 06:21 AM
  XLibre for Mobian Hiraghm 0 3,600 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 356,939 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 3,277 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 4,527 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 5,262 05-06-2025, 02:19 AM
