Vertical clearances inside a PBP case
Are there any engineering diagrams or similar that show vertical clearances inside the case, particularly the amount of space between the inside of the back cover and the various levels of the mainboard? I'm wanting to experiment with better passive cooling and it's hard to tell how thick thermal pads and so on should be.  The only thing I have found is the "principle views" [sic] PDF, which  doesn't appear to contain vertical interior views and has no measurements.
  Fitting new case RicTor 1 1,870 05-19-2026, 03:45 AM
Last Post: fnfgopro
  pinebook pro dixplays vertical stripes WEF 2 5,233 03-23-2025, 03:31 PM
Last Post: WEF
  PinebookPro Bottom Case KC9UDX 1 3,878 12-05-2024, 07:33 AM
  common case for PBP mainboard ? Splinter 1 4,830 09-26-2020, 08:22 PM
Last Post: xmixahlx
Smile DIY Bumper Case elijahr 0 3,244 09-21-2020, 10:56 AM
Last Post: elijahr
