Warning: Don't try T12 tips
Just a warning guys,
I was under influence of a random YT movie where someone was saying that pinecill will possibly take T12 tips.
It will not!
it has similar dimensions and shape but there are very different. T12 are much longer
Don't even try putting it in. It will short the output and damage the iron.
From now the iron is not able to sense the temperature nor regulate it so the tip is fully on, making it glowing red.
For now, I diagnosed that one of the MOSFETs in U13/CJQ7328  is dead short. I don't have one handy. I will let you know later if replacing it fixes the problem.
(07-13-2021, 07:10 AM)csiwek Wrote: Just a warning guys,
It will not!
Just to confirm: Replacing U13/CJQ7328 fixed the problem
It will not!
Good to now. I have dusted off my pinecil - bought long ago, went busy with other projects, needing heavier iron and now, absolutely need this thing to work. Now where did I put that manual. :-)
What a relief!. That's what I did and precisely what happened. I loved it for the few days I had it, before jamming a t12 down it's throat and ruining. But for some reason there was just a little sliver of doubt (Denial) that it was the actual culprit. Now that I have that cold hard evidence against myself. I can order another one.
(10-28-2022, 11:35 PM)Ev3B Wrote: What a relief!. That's what I did and precisely what happened. I loved it for the few days I had it, before jamming a t12 down it's throat and ruining. But for some reason there was just a little sliver of doubt (Denial) that it was the actual culprit. Now that I have that cold hard evidence against myself. I can order another one.
If you push a T12 Tip into Pinecil, it will  hit  things and kill the Mosfett.   it can only be done if you  print a plastic 3D  Mosfet protector for the inside. and even then  why would people do this?   it makes the Pinecil Super long and hard to use.
  Pricing and availability of single tips askaaron 2 11,157 02-04-2023, 01:46 PM
Last Post: askaaron
  Survey on Pinecil Tips, Please fill out River 0 3,052 11-06-2022, 02:43 AM
Last Post: River
  Warning, 5.5mm barrel-style power cables biketool 6 23,164 11-05-2022, 01:47 PM
Last Post: River
  TS-100 tips gadjet 4 8,664 02-17-2022, 11:00 AM
Last Post: gadjet
