PSA: WiFi driver is broken - Unload kernel module to save lots of power
120-170+mA of savings.
rfkill / iface down does not work properly, the wifi module will consume more power when disabled than when enabled. Toggling WiFi off does cause more powerdraw than leaving it on.
PHP Code:
sudo rmmod 8723cs    # kill wifi
sudo modprobe 8723cs # restore wifi
Megi reproduced my findings today and is aware of the issue.
Quote:hmm, right, I can measure 416mA when wlan0 is up, and 505 mA when down, and 380mA when the driver is unloaded
Unloading the kernel module is currently the only workaround.
Maybe let the maintainers of the distro you're using know - I've already notified the SXMO team.
Do you know which kernel version(s) are affected? Presumably a kernel downgrade is another option?
I'm using Manjaro Phosh Beta 11 and I noticed the battery drain before reading this and was wondering what was happening.
(06-22-2021, 08:45 PM)dcinoz Wrote: Do you know which kernel version(s) are affected? Presumably a kernel downgrade is another option?
Probably since 5.10, I know it's an issue on 5.12 for fact, but that driver was put into the 5.10 kernel initially according to megi's blog.
I can confirm this bug for sure.
Wi-Fi off (rmmod): 1.45 W
Wi-Fi on (and connected to AP): 1.55W
Wi-Fi "off" : 1.85 W
linux-pine64 5.12.7-1 phosh 0.11.0-1
This is good to know, I turn my Wi-Fi off when I go to sleep, this should save me some battery LOL.
  Pilotlight, a way to save power during long audio playback biketool 3 5,928 01-10-2025, 03:42 AM
Lightbulb Article: Experiments for super low PinePhone power consumption with Genode Surehand53 1 4,650 12-27-2022, 02:21 PM
Last Post: Samurai_Crow
  Article: NuttX RTOS for PinePhone: Display Driver in Zig lupyuen 0 2,655 10-17-2022, 07:02 PM
Last Post: lupyuen
  Article: NuttX RTOS for PinePhone: UART Driver lupyuen 0 2,182 09-09-2022, 10:35 PM
Last Post: lupyuen
  Most Power Efficient OS Image jwinarske 0 2,207 07-05-2022, 07:05 PM
Last Post: jwinarske
  Keyboard Case Power Management Daemon estokes 2 5,177 04-16-2022, 04:15 PM
Last Post: estokes
  Diagnosing power usage with ZZZtop biketool 1 3,834 10-21-2021, 01:23 PM
  Reviewing our Forebearer's Work re:Power Consumption biketool 0 2,514 10-20-2021, 09:51 AM
  Phosh - config within Settings does not save after reboot antitheos 0 3,025 09-24-2021, 04:30 PM
Last Post: antitheos
  Ubports Wifi Module not Returning Networks acohl 4 8,311 04-21-2021, 03:27 AM
Last Post: NinjaDino29
