3/32 upgrade board, Arrived Without Firmware, Troubleshooting Steps to SOLVED
(skip to last edit to see solution, leaving all steps to make searching for solution easier)
I finally received my new 3/32 upgrade board for my pinephone.
I read the wiki and watched the video, and did the board swap.
It looks like it was not flashed with a bootloader at the factory?
Instead I see a LED flash from the back of the board when I insert the USB and then I lsusb I get
Onda (unverified) V972 tablet in flashing mode
Nothing on the screen though.
I also tried booting a jumpdrive SD but nothing happened, no bootloader,  got the same lsusb response.
(edit)
I found a copy of the factory-test image(pine64-pinephone-20200726-phosh-v20.05-factory.img) on my computer and with that in the SD slot gave me a pink LED when I inserted USB.
I waited an 20min with the pink LED and dark screen in case anything was being flashed.
I then rebooted did the other tests and then chose the automated test, it is sitting for a long time at 12% testing the LIS3MDL after instantly testing MPU-6050.
this link should help you find the factory test image https://images.postmarketos.org/pinephone/
(edit)
For some reason my jumpdrive SD is not working/booting so I am DL'ing from this link the Debian image and will try that once the download is finished.
https://wiki.pine64.org/wiki/PinePhone_S...ry_Test_OS
(edit)
I got the Debian Factory image and booted it, run the auto-test, I don't outright fail and instantly passes the MPU-650, but I never pass the LIS3MDL, just hangs forever at 12% so I never get the option to flash......
(edit)
Got advice after opening a Pine64 service ticket, they recommended I go to
https://wiki.pine64.org/wiki/PinePhone_S..._OS_builds
choose the Beta Edition link and DD the image to SD
This image passes the tests and I am flashing my EMMC, I loaded the OS and ran setup, ran sudo halt and DD the latest JumpDrive to SD
https://github.com/dreemurrs-embedded/Ju...e/releases
Flashed Debian Mobile mobian-pinephone-phosh-20210421.img to EMMC via jumpdrive
Booted and ran Mobian setup on my Pinephone from a 3/32 upgrade board that arrived unconfigured.
now grabbing software updates, and will enable unstable repos once I have everything configured.
https://wiki.mobian-project.org/doku.php...n-unstable
  Firmware update only did partial upgrade? Agent24 2 908 09-26-2026, 05:04 PM
Last Post: Agent24
  eMMC upgrade EuvzO8 5 7,689 11-08-2023, 11:58 PM
Last Post: brken
  Pine phone main board part Generaltuxenburg 1 3,873 07-31-2023, 07:50 PM
  USB C side board out of stock gab 3 5,415 12-29-2022, 11:42 AM
Last Post: fxc
  What Adhesive to buy for daughter board? LogosCoder 1 3,404 11-28-2022, 05:07 PM
  firmware udate Quectel EG25-G modem alwi 7 16,013 07-06-2022, 01:43 PM
Last Post: user641
  Need command to tell what modem firmware I am on. purpletiger 4 8,520 07-06-2022, 12:35 PM
  Connection woes, modem troubleshooting within Bewilderforce 0 3,199 10-06-2021, 04:02 AM
Last Post: Bewilderforce
  camera firmware problems kqlnut 25 43,640 09-02-2021, 07:49 PM
  pinephone circuit board design, conductive parts zetabeta 1 3,986 08-12-2021, 05:28 AM
Last Post: wibble
