Increasing max voltage to use a bigger battery
In https://wiki.pine64.org/wiki/PinePhone_FAQ#Battery it says I can use this to allow my phone to charge more:
echo 4350000 > /sys/class/power_supply/axp20x-battery/voltage_max_design
When I do that however I get a write error, what's going on?
I want to install this battery but it's not going to be able to use the full capacity if I can't set the max voltage, right?
https://www.ebay.co.uk/itm/333992044176
You have to enter it like this:
echo 4350000 | sudo tee /sys/class/power_supply/axp20x-battery/voltage_max_design
(05-30-2021, 01:34 PM)Merc Wrote: You have to enter it like this:
Same issue
tee: /sys/class/power_supply/axp20x-battery/voltage_max_design: Invalid argument
(05-30-2021, 12:55 PM)SocialNetworkingWasAMistake Wrote: In https://wiki.pine64.org/wiki/PinePhone_FAQ#Battery it says I can use this to allow my phone to charge more:
Your initial error is most likely because either you're not executing the command as root, or because the /sys node in question is read-only. I think battery voltage needs to be set very early on, AFAIR it's done in the pinephone version of u-boot. You may need to compile a custom boot loader to actually change that value.
I have no idea why people are suggesting that you use tee, and I wouldn't expect it to work like that. Without any other arguments, tee will (AFAIR) attempt delete the existing node and then create a regular file to output to. I would expect this to fail, as you generally aren't aren't allowed to delete nodes or create regular files in sysfs.
You might be able to get tee to work with tee in append mode, but a far simpler solution is just to execute your original command as root, e.g. with
sudo echo 4350000 > /sys/class/power_supply/axp20x-battery/voltage_max_design
If sudo works, but the write attempt fails, it probably implies that the node isn't writable at all.
The privs granted by sudo stop at the redirect, so you can't redirect into files your user doesn't have write access to. Piping into sudo tee is a common workaround for this limitation, and often used with things in sysfs.
  Battery problem with a Pinephone keyboard and Mobian elode 2 5,771 12-22-2022, 07:10 PM
Last Post: acid andy
  Possible solutions to the battery draining issue? 3x5co 5 8,259 11-28-2022, 10:58 AM
Last Post: 3x5co
  Will this battery-saving script cause problems? rp3 1 3,911 08-28-2022, 02:00 PM
  Battery Management jsch 4 6,472 07-27-2022, 11:17 AM
Last Post: jsch
  Limiting battery charging to some percentage TRS-80 3 7,202 08-22-2021, 01:02 AM
Last Post: bcnaz
  Possible fix for lousy standby battery life? bitnick 5 9,789 02-04-2021, 04:05 PM
Last Post: dcinoz
Sad battery usage HLing 3 8,490 08-29-2020, 06:04 AM
Last Post: User 18618
  SMS after dead battery antiX-Dave 4 10,718 06-05-2020, 08:11 PM
Last Post: antiX-Dave
