Mobian: 2 week as main phone
(05-09-2021, 11:52 AM)steves Wrote: 2. Sometimes the phone when it wakes from sleep will not see it's cell modem. Usually a reboot fixes this, but due to the above issue it can be rather aggravating.
I've been having the same problem. Haven't found the solution either.
(05-09-2021, 11:52 AM)steves Wrote: 6. Alarms don't work if the phone is asleep at the time it's suppose to go off.
There are a couple solutions to this. One is to use Wake Mobile like was kqInit suggested. I've used it successfully already (just got my phone last Friday).
Another is to make a systemd timer that periodically wakes the phone up, which then lets the Alarm app have a chance to activate the alarm periodically. Of course, its accuracy is limited by how often you wake it up (e.g. if you make your phone wake up every 15 minutes, then your alarm will be 0-15 minutes late depending on what you set it to). Adding the timer has the additional advantage that other apps on your phone can also check email and other messages periodically, which they can't do if the phone is asleep all the time. Note, other people have also used a timer for this purpose with success before me, which means that it is reasonably reliable. You need to make two files for the timer in the /etc/systemd/system directory. They should have the same basename but different prefixes. They would be
/etc/systemd/system/BASENAME.service
[Unit] Description=Wake up the system to allow the alarm to work and check messages [Service] ExecStart=/usr/bin/true
/etc/systemd/system/BASENAME.timer
[Unit] Description=Wake up the system to allow the alarm to work and check messages [Timer] Persistent=false WakeSystem=true AccuracySec=1000m OnCalendar=*-*-* *:00,15,30,45:00 [Install] WantedBy=timers.target
Where the "OnCalendar=*-*-* *:00,15,30,45:00" line indicates when it should go off. In my case, I have it set for every 15 minutes. Note the '*' for the year, month, day, and hour fields; the 00 for the second field; and the comma separated values for the minute field giving when it should go off. If you want to do a different interval, you will need to adjust this. I've set the accuracy field to a large value (m is for millisecond) because I don't need the timer to be more accurate than one second.
(05-09-2021, 11:52 AM)steves Wrote: If anyone's interested in the inhibit script here it is:
#!/bin/bash gnome-session-inhibit --inhibit 'idle:suspend' zenity --info --text "Inhibiting sleep. Press ok when ready to stop this"
Just make a .desktop file for it and give it an icon and you're good.
Thanks for the script.
  Printing from Mobian johnd 3 5,008 10-27-2026, 06:01 AM
Last Post: PrinterSolvedTeam
  Mobian MMS/SMS text problem bcnaz 16 40,572 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 2,007 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 71,117 12-24-2025, 12:11 AM
  How to add an homemade app to the main screen? JChdeL 3 2,414 11-04-2025, 04:13 AM
Last Post: JChdeL
  cryptocurrency on mobian/pinephone biketool 33 74,869 10-08-2025, 06:21 AM
  XLibre for Mobian Hiraghm 0 3,564 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 354,134 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 3,244 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 4,472 06-07-2025, 03:19 PM
