05-07-2021, 03:22 AM
Has anyone gotten chatty to send sms over O2 network in Germany? If so how?
Sending SMS carrier: O² Germany
05-08-2021, 10:07 AM
(This post was last modified: 05-08-2021, 10:08 AM by Maus.
Edit Reason: More details
I'm on a Telefónica Moviles MVNO (same carrier as O2) and can confirm that sending text messages with chatty only seems to work (chatty marks them as sent, but they're never received on the other end). Receiving text messages works OK, but at this moment I wanted to check this and it seems to have lost the messages database: zilch!
This definitely worked when I started to use the phone as daily driver ...
05-11-2021, 09:19 AM
(This post was last modified: 05-11-2021, 09:20 AM by arno_nuehm.)
Sadly, yes, I can confirm, that SMS messages are not received, if sent via Chatty/O2Germany - it worked some weeks ago though.
But thanks for pointing that out. I will try to get some logs and open an issue on gitlab(?). Cheers
05-11-2021, 01:51 PM
Has anyone tried this?
https://gitlab.com/mobian1/issues/-/issues/254
05-12-2021, 07:45 AM
If Chatty is the standard, preinstalled & bookmarked SMS client: I don't seem to have any problems sending or receiving messages via O2 Germany.
05-12-2021, 01:45 PM
(This post was last modified: 05-12-2021, 01:49 PM by Maus.
Edit Reason: Added ModemManager log info
(05-11-2021, 01:51 PM)sfb Wrote: Has anyone tried this? I tried this, intending to switch off IMS for some time in the running configuration of the modem, using mmcli to poke the modem's configuration directly. It didn't work. Sending text messages directly via mmcli also does not work any more, which tells me it isn't a Chatty problem, but with the middleware (ModemManager or eg25-manager). Code: root@pine:~# mmcli -m any --messaging-create-sms="text='Hello world test',number='+44123456789'"journalctl tells this after some seconds: Code: ModemManager[583]: transaction 0xd aborted, but message is not abortable
05-12-2021, 01:55 PM
(This post was last modified: 05-12-2021, 01:58 PM by arno_nuehm.)
(05-12-2021, 01:45 PM)Maus Wrote:(05-11-2021, 01:51 PM)sfb Wrote: Has anyone tried this? Thanks for testing and eliminating Chatty as the culprit... So it looks like a ModemManager thing, isn't it? (05-12-2021, 07:45 AM)Anna Wrote: If Chatty is the standard, preinstalled & bookmarked SMS client: I don't seem to have any problems sending or receiving messages via O2 Germany. That's good! Is your Mobian up-to-date?
05-12-2021, 02:18 PM
(05-12-2021, 01:55 PM)arno_nuehm Wrote: That's good! Is your Mobian up-to-date? Pretty much -- except for these: Code: at-spi2-core/testing 2.38.0-4 arm64 [upgradable from: 2.38.0-2]
05-13-2021, 10:53 PM
[quote pid='94594' dateline='1620850684']
Code: at-spi2-core/testing 2.38.0-4 arm64 [upgradable from: 2.38.0-2][/quote] Do you guys think any of those could be at fault?
05-14-2021, 05:46 AM
(05-13-2021, 10:53 PM)Anna Wrote: [quote pid='94594' dateline='1620850684'] Do you guys think any of those could be at fault? [/quote] As far as I see, there is nothing related to this problem - no risk regarding the updates. |
| MMS Carrier Settings | biketool | 0 | 1,369 |
10-20-2024, 09:19 AM Last Post: biketool |
| Sending Pinephone SMS from Desktop | biketool | 5 | 7,102 |
09-13-2022, 01:46 PM Last Post: anonymous |
| WIRED-PROPERTIES.CARRIER: off | --- | 1 | 4,538 |
09-24-2020, 05:03 AM Last Post: --- |
