GPS Antenna - external connector?
I checked and that is the GNSS antenna feed.
[Image: feed.jpg]
The green arrow points to the 0ohm resistor that should be removed. Then the signal can be fed to the red pad.
But yeah these pads are tiny.
When looking for GPS alternatives I saw a few I2C units. I don't think it is possible to get GPSD to work with an I2C source, but should be usable for just about anything else. https://learn.adafruit.com/adafruit-mini...le/arduino
It might also be possible to use the headphone console as a normal serial port.
I bought one of these GPS amplifiers. https://www.amazon.com/gp/product/B07SJ64Q3X
Price is even cheaper then when I bought mine. Search for ANT-1573, they seem to be having a price war.
It works.
Stock PinePhone with amplifier repeater sitting right on top the corner of the case above the GPS antenna. On the right is the Franken-Phone with ceramic patch antenna. The amplifiers antenna is about 6 feet away.
[Image: repeater.PNG]
This will probably be my solution for use in car.
Thanks @8bit, much appreciated.
I haven't been able to try the alternate signal path (my soldering skills aren't good enough), but I have acquired a ublox7 GPS dongle which is giving good enough results for my purposes.
Cheers!
a second external connector was a good idea
Im wondering if a case could be made that uses the 6 pins on the back as a powered antenna break out. In my area signal strength is poor so I would sacrifice pocketability and battery for more reception for gps and 2g,3g,4g.
  Battery connector dead mdk 5 5,351 01-15-2026, 02:24 PM
Last Post: mikeb
  USB-C connector Overheated and melted nickbenjones 2 5,356 05-26-2023, 06:16 PM
  External Antenna port daily driver on Verizon Billthompson 6 10,608 04-30-2022, 09:51 PM
Last Post: TheBusyWizard
  Connect external modem? feklee 7 11,499 12-06-2021, 03:52 AM
Last Post: feklee
  Fragile SIM card connector hakkou 1 3,903 08-25-2021, 07:44 AM
Last Post: wibble
  USB C connector loose? bceverly 3 6,553 08-10-2021, 09:44 AM
Last Post: c3l@
  Micro-USB 3.0 connector for the PinePhone? Peter Gamma 1 4,411 03-10-2021, 10:11 AM
Last Post: wibble
  broken connector-pin for the accu alwi 2 6,182 02-23-2021, 06:28 AM
Last Post: scholbert
  external speaker mascarade01 5 16,465 12-16-2020, 07:32 AM
Last Post: mascarade01
  Main Board Swap: Camera connector problems tyha 5 10,625 11-19-2020, 06:25 PM
Last Post: pajux
