1GB Pine64+ freezes/crashes with all installs
(05-12-2016, 08:44 AM)tkaiser Wrote: Where did you measure? Pins 2/6 on Euler connector or somewhere else?
2+8/34 on e-connector, and directly on the rails of the connector from the supply as well for good measure.
I can run a USB mouse, USB keyboard and ethernet network together while at the same time putting all four cores on full blast without a single hiccup when powering the Pine via the 5V USB connector, but maximizing the available bandwidth on the much less power-consuming WiFi link does not work, not even with mouse+keyboard disconnected and no mentionable load on the SoC.
  Pine64 Suddenly Turnoff with Lcd mix359 4 15,910 07-08-2021, 08:50 AM
Last Post: e-minguez
  Pine64 (analog) Audio Jack Output w/ Kernel 4.19 ecolezen 0 6,107 01-24-2019, 07:00 AM
Last Post: ecolezen
  PINE64 STEREO AUDIO DAC POT jtgiroux 0 6,090 01-12-2019, 04:56 PM
Last Post: jtgiroux
  Does Pine64+ have an internal hardware watchdog ? rahlquist 8 24,778 04-26-2018, 06:27 PM
Last Post: pfeerick
  Using the pine64 with AVR - HDMI pass-through Moshe.Vazan 4 10,088 01-02-2017, 02:58 PM
Last Post: Moshe.Vazan
  I dropped my Pine64 DukeJustice 17 33,832 11-07-2016, 07:23 PM
Last Post: DukeJustice
  pine64+ cad files danlcarr 1 5,922 08-31-2016, 08:26 AM
Last Post: martinayotte
  Pine64+: 3 working, 1 shows nothing on tv zumtra 1 6,802 07-30-2016, 05:47 PM
  mounting root filesystem via NFS on pine64+ issue martind1983 2 7,485 07-29-2016, 06:37 AM
Last Post: martind1983
  Cannot get PINE64 boards to boot andymelton 13 28,106 07-06-2016, 09:20 AM
Last Post: montero65
