Spontaneous numlock
#31
I'm pretty sure it doesn't, I'll check again in a little while when I switch back. But the Pause and Scroll lock (or print screen) turn the numlock LED on and off. It's like the keycodes are wrong, that's why I was wondering if ansi and iso keyboards use different dtbs. But on a similar note in Manjaro the # key gives me a British Pound symbol so the keyboard type may be wrong. That could affect numlock maybe?
The speaker still doesn't switch in Debian Bullseye. But numlock doesn't work. F12/Pause and F9/Print screen are doing a full numlock, both the LED turns on and characters that get typed change to numbers for the keys with numbers.
Did you select the right keyboard type in Manjaro ARM, when you were asked for it?
I think so, I wasn't planning to keep it.  I'm in Manjaro now.  The speakers do turn off when you plug in headphones.
Numlock doesn't work but F9 and F12 give numlock, same as in Debian.  I haven't found in Manjaro where you switch keyboard settings.  I also installed LXDE but I haven't figured out how to switch yet.
dumpkeys says:
keymaps 0-2,4-6,8-9,12
keycode   1 = Escape
    alt    keycode   1 = Meta_Escape
    shift    alt    keycode   1 = Meta_Escape
    control    alt    keycode   1 = Meta_Escape
keycode   2 = one              exclam
    alt    keycode   2 = Meta_one
    shift    alt    keycode   2 = Meta_exclam
keycode   3 = two              quotedbl         at
    control    keycode   3 = nul
    alt    keycode   3 = Meta_two
    shift    alt    keycode   3 = Meta_quotedbl
    control    alt    keycode   3 = Meta_nul
keycode   4 = three
    control    keycode   4 = Escape
    alt    keycode   4 = Meta_three
keycode   5 = four             dollar           dollar
    control    keycode   5 = Control_backslash
    alt    keycode   5 = Meta_four
    shift    alt    keycode   5 = Meta_dollar
    control    alt    keycode   5 = Meta_Control_backslash
keycode   6 = five             percent
    control    keycode   6 = Control_bracketright
    alt    keycode   6 = Meta_five
    shift    alt    keycode   6 = Meta_percent
keycode   7 = six              asciicircum
    control    keycode   7 = Control_asciicircum
    alt    keycode   7 = Meta_six
    shift    alt    keycode   7 = Meta_asciicircum
keycode   8 = seven            ampersand        braceleft
    control    keycode   8 = Control_underscore
    alt    keycode   8 = Meta_seven
    shift    alt    keycode   8 = Meta_ampersand
    control    alt    keycode   8 = Meta_Control_underscore
keycode   9 = eight            asterisk         bracketleft
    control    keycode   9 = Delete
    alt    keycode   9 = Meta_eight
    shift    alt    keycode   9 = Meta_asterisk
    control    alt    keycode   9 = Meta_Delete
keycode  10 = nine             parenleft        bracketright
    alt    keycode  10 = Meta_nine
    shift    alt    keycode  10 = Meta_parenleft
keycode  11 = zero             parenright       braceright
    alt    keycode  11 = Meta_zero
    shift    alt    keycode  11 = Meta_parenright
keycode  12 = minus            underscore       backslash
    control    keycode  12 = Control_underscore
    alt    keycode  12 = Meta_minus
    shift    alt    keycode  12 = Meta_underscore
    control    alt    keycode  12 = Meta_Control_underscore
keycode  13 = equal            plus
    alt    keycode  13 = Meta_equal
    shift    alt    keycode  13 = Meta_plus
keycode  14 = Delete
    control    keycode  14 = Control_underscore
    alt    keycode  14 = Meta_Delete
    shift    alt    keycode  14 = Meta_Delete
    control    alt    keycode  14 = Meta_Control_underscore
keycode  15 = Tab
    shift    keycode  15 = Meta_Tab
    alt    keycode  15 = Meta_Tab
    control    alt    keycode  15 = Meta_Tab
keycode  16 = q
keycode  17 = w
keycode  18 = e
keycode  19 = r
keycode  20 = t
keycode  21 = y
keycode  22 = u
keycode  23 = i
keycode  24 = o
keycode  25 = p
keycode  26 = bracketleft      braceleft
    control    keycode  26 = Escape
    alt    keycode  26 = Meta_bracketleft
    shift    alt    keycode  26 = Meta_braceleft
keycode  27 = bracketright     braceright       asciitilde
    control    keycode  27 = Control_bracketright
    alt    keycode  27 = Meta_bracketright
    shift    alt    keycode  27 = Meta_braceright
    control    alt    keycode  27 = Meta_Control_bracketright
keycode  28 = Return
    alt    keycode  28 = Meta_Control_m
keycode  29 = Control
keycode  30 = a
keycode  31 = s
keycode  32 = d
keycode  33 = f
keycode  34 = g
keycode  35 = h
keycode  36 = j
keycode  37 = k
keycode  38 = l
keycode  39 = semicolon        colon
    alt    keycode  39 = Meta_semicolon
    shift    alt    keycode  39 = Meta_colon
keycode  40 = apostrophe       at
    control    keycode  40 = Control_g
    shift    control    keycode  40 = nul
    alt    keycode  40 = Meta_apostrophe
    shift    alt    keycode  40 = Meta_at
keycode  41 = grave
    altgr    keycode  41 = bar
    control    keycode  41 = nul
    alt    keycode  41 = Meta_grave
    control    alt    keycode  41 = Meta_nul
keycode  42 = Shift
keycode  43 = numbersign       asciitilde
    control    keycode  43 = Control_backslash
    alt    keycode  43 = Meta_numbersign
    shift    alt    keycode  43 = Meta_asciitilde
keycode  44 = z
keycode  45 = x
keycode  46 = c
keycode  47 = v
keycode  48 = b
keycode  49 = n
keycode  50 = m
keycode  51 = comma            less
    alt    keycode  51 = Meta_comma
    shift    alt    keycode  51 = Meta_less
keycode  52 = period           greater
    alt    keycode  52 = Meta_period
    shift    alt    keycode  52 = Meta_greater
keycode  53 = slash            question
    control    keycode  53 = Delete
    alt    keycode  53 = Meta_slash
    shift    alt    keycode  53 = Meta_question
keycode  54 = Shift
keycode  55 = KP_Multiply
    altgr    keycode  55 = Hex_C
keycode  56 = Alt
keycode  57 = space
    control    keycode  57 = nul
    alt    keycode  57 = Meta_space
    shift    alt    keycode  57 = Meta_space
    control    alt    keycode  57 = Meta_nul
keycode  58 = Caps_Lock
keycode  59 = F1               F13              Console_13
    control    keycode  59 = F25
    alt    keycode  59 = Console_1
    control    alt    keycode  59 = Console_1
keycode  60 = F2               F14              Console_14
    control    keycode  60 = F26
    alt    keycode  60 = Console_2
    control    alt    keycode  60 = Console_2
keycode  61 = F3               F15              Console_15
    control    keycode  61 = F27
    alt    keycode  61 = Console_3
    control    alt    keycode  61 = Console_3
keycode  62 = F4               F16              Console_16
    control    keycode  62 = F28
    alt    keycode  62 = Console_4
    control    alt    keycode  62 = Console_4
keycode  63 = F5               F17              Console_17
    control    keycode  63 = F29
    alt    keycode  63 = Console_5
    control    alt    keycode  63 = Console_5
keycode  64 = F6               F18              Console_18
    control    keycode  64 = F30
    alt    keycode  64 = Console_6
    control    alt    keycode  64 = Console_6
keycode  65 = F7               F19              Console_19
    control    keycode  65 = F31
    alt    keycode  65 = Console_7
    control    alt    keycode  65 = Console_7
keycode  66 = F8               F20              Console_20
    control    keycode  66 = F32
    alt    keycode  66 = Console_8
    control    alt    keycode  66 = Console_8
keycode  67 = F9               F21              Console_21
    control    keycode  67 = F33
    alt    keycode  67 = Console_9
    control    alt    keycode  67 = Console_9
keycode  68 = F10              F22              Console_22
    control    keycode  68 = F34
    alt    keycode  68 = Console_10
    control    alt    keycode  68 = Console_10
keycode  69 = Num_Lock
    altgr    keycode  69 = Hex_A
keycode  70 = Scroll_Lock      Show_Memory      Show_Registers
    control    keycode  70 = Show_State
    alt    keycode  70 = Scroll_Lock
keycode  71 = KP_7
    altgr    keycode  71 = Hex_7
    alt    keycode  71 = Ascii_7
keycode  72 = KP_8
    altgr    keycode  72 = Hex_8
    alt    keycode  72 = Ascii_8
keycode  73 = KP_9
    altgr    keycode  73 = Hex_9
    alt    keycode  73 = Ascii_9
keycode  74 = KP_Subtract
    altgr    keycode  74 = Hex_D
keycode  75 = KP_4
    altgr    keycode  75 = Hex_4
    alt    keycode  75 = Ascii_4
keycode  76 = KP_5
    altgr    keycode  76 = Hex_5
    alt    keycode  76 = Ascii_5
keycode  77 = KP_6
    altgr    keycode  77 = Hex_6
    alt    keycode  77 = Ascii_6
keycode  78 = KP_Add
    altgr    keycode  78 = Hex_E
keycode  79 = KP_1
    altgr    keycode  79 = Hex_1
    alt    keycode  79 = Ascii_1
keycode  80 = KP_2
    altgr    keycode  80 = Hex_2
    alt    keycode  80 = Ascii_2
keycode  81 = KP_3
    altgr    keycode  81 = Hex_3
    alt    keycode  81 = Ascii_3
keycode  82 = KP_0
    altgr    keycode  82 = Hex_0
    alt    keycode  82 = Ascii_0
keycode  83 = KP_Period
    altgr    control    keycode  83 = Boot
    control    alt    keycode  83 = Boot
keycode  84 = Last_Console
keycode  86 = backslash        bar              bar
    control    keycode  86 = Control_backslash
    alt    keycode  86 = Meta_backslash
    shift    alt    keycode  86 = Meta_bar
    control    alt    keycode  86 = Meta_Control_backslash
keycode  87 = F11              F23              Console_23
    control    keycode  87 = F35
    alt    keycode  87 = Console_11
    control    alt    keycode  87 = Console_11
keycode  88 = F12              F24              Console_24
    control    keycode  88 = F36
    alt    keycode  88 = Console_12
    control    alt    keycode  88 = Console_12
keycode  96 = KP_Enter
    altgr    keycode  96 = Hex_F
keycode  97 = Control
keycode  98 = KP_Divide
    altgr    keycode  98 = Hex_B
keycode  99 = Compose
    control    keycode  99 = Control_backslash
    alt    keycode  99 = Control_backslash
    control    alt    keycode  99 = Meta_Control_backslash
keycode 100 = AltGr
    alt    keycode 100 = Compose
keycode 101 = Break
keycode 102 = Find
keycode 103 = Up
    alt    keycode 103 = KeyboardSignal
keycode 104 = Prior
    shift    keycode 104 = Scroll_Backward
keycode 105 = Left
    alt    keycode 105 = Decr_Console
keycode 106 = Right
    alt    keycode 106 = Incr_Console
keycode 107 = Select
keycode 108 = Down
keycode 109 = Next
    shift    keycode 109 = Scroll_Forward
keycode 110 = Insert
keycode 111 = Remove
    altgr    control    keycode 111 = Boot
    control    alt    keycode 111 = Boot
keycode 112 = Macro
    altgr    control    keycode 112 = VoidSymbol
    shift    alt    keycode 112 = VoidSymbol
keycode 113 = F13
    altgr    control    keycode 113 = VoidSymbol
    shift    alt    keycode 113 = VoidSymbol
keycode 114 = F14
    altgr    control    keycode 114 = VoidSymbol
    shift    alt    keycode 114 = VoidSymbol
keycode 115 = Help
    altgr    control    keycode 115 = VoidSymbol
    shift    alt    keycode 115 = VoidSymbol
keycode 116 = Do
    altgr    control    keycode 116 = VoidSymbol
    shift    alt    keycode 116 = VoidSymbol
keycode 117 = F17
    altgr    control    keycode 117 = VoidSymbol
    shift    alt    keycode 117 = VoidSymbol
keycode 118 = KP_MinPlus
    altgr    control    keycode 118 = VoidSymbol
    shift    alt    keycode 118 = VoidSymbol
keycode 119 = Pause
string F1 = "\033[[A"
string F2 = "\033[[B"
string F3 = "\033[[C"
string F4 = "\033[[D"
string F5 = "\033[[E"
string F6 = "\033[17~"
string F7 = "\033[18~"
string F8 = "\033[19~"
string F9 = "\033[20~"
string F10 = "\033[21~"
string F11 = "\033[23~"
string F12 = "\033[24~"
string F13 = "\033[25~"
string F14 = "\033[26~"
string F15 = "\033[28~"
string F16 = "\033[29~"
string F17 = "\033[31~"
string F18 = "\033[32~"
string F19 = "\033[33~"
string F20 = "\033[34~"
string Find = "\033[1~"
string Insert = "\033[2~"
string Remove = "\033[3~"
string Select = "\033[4~"
string Prior = "\033[5~"
string Next = "\033[6~"
string Macro = "\033[M"
string Pause = "\033[P"
compose '`' 'A' to Agrave
compose '`' 'a' to agrave
compose '\'' 'A' to Aacute
compose '\'' 'a' to aacute
compose '^' 'A' to Acircumflex
compose '^' 'a' to acircumflex
compose '~' 'A' to Atilde
compose '~' 'a' to atilde
compose '"' 'A' to Adiaeresis
compose '"' 'a' to adiaeresis
compose 'O' 'A' to Aring
compose 'o' 'a' to aring
compose '0' 'A' to Aring
compose '0' 'a' to aring
compose 'A' 'A' to Aring
compose 'a' 'a' to aring
compose 'A' 'E' to AE
compose 'a' 'e' to ae
compose ',' 'C' to Ccedilla
compose ',' 'c' to ccedilla
compose '`' 'E' to Egrave
compose '`' 'e' to egrave
compose '\'' 'E' to Eacute
compose '\'' 'e' to eacute
compose '^' 'E' to Ecircumflex
compose '^' 'e' to ecircumflex
compose '"' 'E' to Ediaeresis
compose '"' 'e' to ediaeresis
compose '`' 'I' to Igrave
compose '`' 'i' to igrave
compose '\'' 'I' to Iacute
compose '\'' 'i' to iacute
compose '^' 'I' to Icircumflex
compose '^' 'i' to icircumflex
compose '"' 'I' to Idiaeresis
compose '"' 'i' to idiaeresis
compose '-' 'D' to ETH
compose '-' 'd' to eth
compose '~' 'N' to Ntilde
compose '~' 'n' to ntilde
compose '`' 'O' to Ograve
compose '`' 'o' to ograve
compose '\'' 'O' to Oacute
compose '\'' 'o' to oacute
compose '^' 'O' to Ocircumflex
compose '^' 'o' to ocircumflex
compose '~' 'O' to Otilde
compose '~' 'o' to otilde
compose '"' 'O' to Odiaeresis
compose '"' 'o' to odiaeresis
compose '/' 'O' to Ooblique
compose '/' 'o' to oslash
compose '`' 'U' to Ugrave
compose '`' 'u' to ugrave
compose '\'' 'U' to Uacute
compose '\'' 'u' to uacute
compose '^' 'U' to Ucircumflex
compose '^' 'u' to ucircumflex
compose '"' 'U' to Udiaeresis
compose '"' 'u' to udiaeresis
compose '\'' 'Y' to Yacute
compose '\'' 'y' to yacute
compose 'T' 'H' to THORN
compose 't' 'h' to thorn
compose 's' 's' to ssharp
compose '"' 'y' to ydiaeresis
compose 's' 'z' to ssharp
compose 'i' 'j' to ydiaeresis
I think in the setup there was only one keyboard question, like country but not number of keys.
Quite frankly, something weird seems to be going on...  Could the keyboard actually be faulty?  Have you, maybe, spilled some liquid into the keyboard?  Does xev print anything when you press the NumLock key?  What happens when you press the NumLock key while you're on the virtual console (Ctrl+Alt+F1)?
Well, at least the built-in speakers now turn off automatically when you plug in the headphones.
Last time I tired to use a virtual console in Manajro the original never came back. It was busy doing some GUI thing that was slow so I switched. When I switched back it stayed black. Like I was lookiing at a framebuffer that needed to repaint.
I don't have xev installed. I don't normally use numlock so I don't know if it works. It came on when I didn't want it.
Posting then switching consoles in case it doesn't come back again.
Let's see if the switching to the virtual console and back will work this time.
Last time I tried to use a virtual console in Manjaro the original never came back. It was busy doing some GUI thing that was slow so I switched. When I switched back it stayed black. Like I was lookiing at a framebuffer that needed to repaint.
It didn't come back and the network's dropping out like Network Manager is running. The GUI didn't come back so I switched back to the virtual terminal and typed pkill x. Then when I did ctl-alt-F1 it gave me a GUI login box and started a new session. So opendm is running or something. I normally boot to a console then type startx. Ican actually run X and Wayland in different consoles but it's crashy that way. X and a console mostly work fine.
Let's see if I can get to the network and get this out. Firefox kept it before even though X wasn't running.
I had to disconnect then reconnect the wifi. A few times. That's bogus. MPV is running at 25% CPU, disapointing. not using the GPU enough.
You should have xev, it comes with X. Unless you're using Wayland (I don't know anything about it).
It reports keycode 77 (keysym0xff7f, Num_Lock) on mine.
Note that Manjaro is known to change your keyboard to the wrong layout by itself! You'll have to check the keyboard settings and make sure they are correct.
It reports 78, Scroll_Lock on mine, but I'm back in Debian. Several of the keys in that area seem to be off by 1. Num_Lock is actually on the Print Screen key. And both Print Screen and Pause will toggle Num_Lock and cause numbers to print instead of letters.
KeyPress event, serial 48, synthetic NO, window 0x2a00001,
    root 0x22b, subw 0x2a00002, time 10173268, (33,37), root:(355,236),
    state 0x0, keycode 78 (keysym 0xff14, Scroll_Lock), same_screen YES,
    XLookupString gives 0 bytes:
    XmbLookupString gives 0 bytes:
    XFilterEvent returns: False
How do you change it in Manajro? I saw a couple places that I'm using a 105 key generic layout but that's as close as I got. I didn't count them but it's probably more than 101.
Just because xev comes with X it doesn't mean your distribution is going to include it. I use xwd so in Debian I have the x11-apps deb installed. I do some xlib programming sometimes, when covid was just starting to hit the US I wrote a simulator in xlib: https://sourceforge.net/projects/epidemicsim/
This will do a screen dump even over an ssh connection but it requires xwd. And it doesn't do well on frame buffers. I call it rdump.
#!/bin/bash
datestr=`date +"%Y-%m-%d_%H-%M"`
outname=/tmp/ss_$datestr.xwd
echo "Saved as " $outname
echo "You have 5 seconds"
sleep 5
xwd -display ':0.0' -root -out $outname
I count 78 keys.  Very small number but having to push Fn so much is annoying.
Users browsing this thread: 30 Guest(s)
