Fail safe way to update ANX7688 firmware
#21
https://xnux.eu/log/#031 the anx firmware can now be flashed on up to date 5.10 and 5.11 kernels
(03-23-2021, 07:28 AM)Artturin Wrote: https://xnux.eu/log/#031 the anx firmware can now be flashed on up to date 5.10 and 5.11 kernels
Hey Artturin,
thanks for the hint... but these enhancements are only valid for megous kernel sources and the distributions using his kernel (e.g. Manajaro).
Mobian people may have to wait a little bit i guess.
Anyway it's great to see it getting fixed.
Cheers,
scholbert
I've said it previously that I had zero issue with flashing on Mobian's kernel. I'm not sure where this claim comes from that flashing is not compatible with 5.10.
(03-26-2021, 09:05 AM)zborgerd Wrote: I've said it previously that I had zero issue with flashing on Mobian's kernel. I'm not sure where this claim comes from that flashing is not compatible with 5.10.
Hey zborgerd,
thanks for pointing this out again... i can't remember exactely, but i ran into trouble with my kernel version.
That's why i started this thread Cool
Anyway, it's still a safe way to go using the test image, if someone's running into trouble.
Cheers,
scholbert
Hey zborgerd,
Cheers,
scholbert
I know that Megi specifically has indicated that his kernel had the problem (via his blog), so that could be part of it. Maybe related to some patches.
  Firmware update only did partial upgrade? Agent24 2 1,102 09-26-2026, 05:04 PM
Last Post: Agent24
  firmware udate Quectel EG25-G modem alwi 7 16,154 07-06-2022, 01:43 PM
Last Post: user641
  Need command to tell what modem firmware I am on. purpletiger 4 8,604 07-06-2022, 12:35 PM
  camera firmware problems kqlnut 25 44,028 09-02-2021, 07:49 PM
  3/32 upgrade board, Arrived Without Firmware, Troubleshooting Steps to SOLVED biketool 0 3,338 06-22-2021, 10:03 AM
  WIFI not available after anx7688 update failure frimmel 21 37,530 05-11-2021, 02:45 AM
Last Post: frimmel
  Pinephone mainboard v1.2 documentation update? scholbert 1 5,175 01-18-2021, 09:01 PM
Last Post: bokomaru
  New motherboard - ANX firmware won't flash. --- 17 26,943 12-26-2020, 01:53 PM
Last Post: p1x3l3d
  Update to 3GB/32GB mainboard not working tlo 2 6,921 11-09-2020, 04:40 PM
Last Post: tlo
  BraveHeart UbPorts Battery drain/Solder update Vlodka 2 7,183 10-04-2020, 11:18 PM
Last Post: Vlodka
