Unable to mount the INTERNAL SD Card
I've tried with a few SD Cards now, both 512 Gig formatted exfat, and tge cards are not showing up on boot, "dmesg" and "lsblk" are not showing them as well.
I'm running Phosh, is it an issue with Phosh?
I'm able to mount the SD Card via an OTG cable, as well as a Windows computer
(03-29-2021, 10:46 PM)dgdimick Wrote: I've tried with a few SD Cards now, both 512 Gig formatted exfat, and tge cards are not showing up on boot, "dmesg" and "lsblk" are not showing them as well.
what do you see when you run this directly after inserting card:
sudo dmesg | tail -20
- RTP
"In the beginner's mind there are many possibilities, in the expert's mind there are few." -Shunryu Suzuki
[ Pinephone Original | Pinetab v1 / v2 Enjoyer ]
Linux Device Privacy / Security Playlist
(03-29-2021, 10:46 PM)dgdimick Wrote:  formatted exfat,
Linux can't handle exfat without installing the exfat library...
Thanks for the reply,
I should have been clearer, I have installed the exfat libs. I assumed by stating that I can mount the SD card using a USB adapter and a OTG cable would have been inferred this - my bad for being unclear.
I do thank you for making sure I'd installed the libs, since this could be a core issue.
Any other ideas?
Thanks for the reply.
Since the SD Card is installed in the Slot INSIDE the phone, I'm not sure what your asking. I've run dmesg a number of times trying to find any "/dev" entries.
When I use the OTG and an SD Card to USB adapter it comes up as /dev/sda1 and allows me to mount it, R/W.
  Does Ubuntu modify a Pinephone SD boot card? Peter Gamma 0 2,589 10-05-2023, 09:18 AM
Last Post: Peter Gamma
  External SD card not listed by Pcmanfm? Peter Gamma 1 3,748 08-22-2023, 12:22 PM
  Device memory full on multi-boot SD card Peter Gamma 4 6,982 08-27-2022, 10:03 AM
Last Post: Eugo
  wiping u-boot off sd card shulamy 6 8,801 08-17-2022, 03:38 AM
Last Post: shulamy
  Quick and easy bootloader option for JumpDrive on external SD card? Peter Gamma 5 7,141 05-02-2022, 06:57 AM
  Writing to SD card possible with all applications? Peter Gamma 5 8,119 03-28-2022, 07:12 AM
  Linux Mint can't mount image made with dd nelstomlinson 0 2,486 11-11-2021, 10:59 AM
Last Post: nelstomlinson
  Launching OS in the SD card from p-boot in MMC chuso 0 2,675 10-01-2021, 09:02 AM
Last Post: chuso
  Silly Kali Linux script for Mobian SD card sergio.pantalone 0 5,160 03-08-2021, 10:08 PM
Last Post: sergio.pantalone
  SD card mounted to access music files unable to play dcinoz 3 6,998 02-24-2021, 11:48 PM
Last Post: dcinoz
