2020-11-13 Image status.
#21
I've try to reinstall on the eMMC memory Mobian, I've try to use an SD-Card with Mobian and Manjaro : NOTHING  Sad
I think that the OS doesn't managed the charge of the battery correctly.
The battery could be dead : https://forum.pine64.org/showthread.php?...5#pid92215
With the dedicated charger, the problem is solved : https://forum.pine64.org/showthread.php?...0#pid92380
For the new encrypted install in the eMMC, I've used ext4 filesystem this time. The first 'apt dist-upgrade' modify '/boot/initrd.5.10-sunx64' as the last time but without error. So, I think for an encrypted filesystem, 'f2fs' is a bad idea.
A new battery tested with success : https://forum.pine64.org/showthread.php?...8#pid92768
  • King's Cross, Termit :   Since I have reinstalled Mobian with the encrypted support, I can't find the 'French' keyboard to have the accented letters in a terminal. The accented letters are presents in the SMS application. I'm looking for the "Français", not the "Français (variante)" that is the alone proposed. The problem is I can't have the accented letters. It could seems only annoying, but the problem is that some directories created by the system have accented letters. By example, the 'Downloads' directory is 'Téléchargements', so it's impossible in a console ('King's Cross' or 'Termit') to type the name of these directories or a file with accented letters. How to reinstall the 'Français' layout and not the variants ?
They've made a mess in latest squeekboard version. It is globally better but things have changed and the doc didn't reflect everything (had to read the code to figure it out)
To use a given french layout for the terminal layout you have to drop a fr.yaml file in ~/.local/share/squeekboard/keyboards/terminal ...
(04-20-2021, 12:28 PM)fdlamotte Wrote: They've made a mess in latest squeekboard version. It is globally better but things have changed and the doc didn't reflect everything (had to read the code to figure it out)
Thank you Fdlamotte.
I've try to find a YAM file or YML without success :
$ dpkg -S "*.yaml" vim-runtime: /usr/share/vim/registry/vim-runtime.yaml python3-yaml: /usr/share/doc/python3-yaml/examples/pygments-lexer/example.yaml extrepo: /etc/extrepo/config.yaml
Where to find the 'fr.yaml' ?
My battery is not usable just now : the Pinephone is not usable for a while.  Huh
I must use my spare battery.
I didn't find it either, before it was in /usr/share... but it seems the yaml are now integrated in the binary Sad
you can find yaml files in the squeekboard gitlab
I use my own fr.yaml (and fr_wide.yaml) here they are, you can uncompress from home, forum doesn't accept yaml files as attachment.
.gz   fr_term_yaml.tar.gz (Size: 1.6 KB / Downloads: 559)
(04-20-2021, 02:42 PM)fdlamotte Wrote: I didn't find it either, before it was in /usr/share... but it seems the yaml are now integrated in the binary Sad
Thank you  Smile
I've downloaded and installed the files this morning. Squeekboard is searching in 'keyboards' sub-directory and not in 'keyboards/terminal' and looking for a 'fr+oss.yaml' file, a soft link is easy to do.
After installed the files, an update of Squeekboard was available. I've rename the 'squeekboard' to 'squeekboard.fr' and install the updates. After a reboot :  Wink The accented letters are usable.
I'm happy to have you files, because I can use it to have a personal configuration, like 'Bépo' maybe.
Have a good day.
The automatic rotation is working  Smile
Thank you !
Yes, the automatic rotation is enable, but in landscape mode, the keyboard's size is smaller than in portrait mode :-(
But, the developers are on the good road and the automatic rotation is very useful  Smile
(04-22-2021, 11:09 AM)Gribouille Wrote: Yes, the automatic rotation is enable, but in landscape mode, the keyboard's size is smaller than in portrait mode :-(
you should try my keyboard in landscape Wink
  Mobian image for the PinePhone Korfou 2 2,117 04-27-2026, 09:57 AM
Last Post: Korfou
  Mobian repository status henrythemouse 16 24,772 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 2,294 03-18-2024, 08:54 PM
Last Post: penguins_rule
  Most recent Mobian image or installer image known to work? DrPlamsa 13 16,998 02-26-2023, 11:47 PM
Last Post: SukiiPooru
  Fast image viewer? vusra 0 2,112 04-25-2022, 04:09 AM
Last Post: vusra
  Status update 2020-12-15 a-wai 33 66,245 01-13-2021, 07:14 AM
Last Post: scott_VYuCAbn3k1NFK
  My Daily QA - 2020-10-06 AmazingNutria 6 12,502 01-05-2021, 10:08 PM
Last Post: daniel
  Why the 12/15/2020 build is no where near a daily driver yet TheLastDon 24 40,125 12-31-2020, 09:51 AM
Last Post: HLing
  Status update 2020-11-15 a-wai 17 29,071 12-05-2020, 05:58 PM
Last Post: bcnaz
  Status update 2020-09-05 a-wai 26 50,270 10-12-2020, 01:50 PM
Last Post: dukla2000
