Jack size
The official replacement power cable is described here as having a "Type H" jack. The most precise information I managed to find on Type H via an internet search was this Amazon product page, which describes its Type H jack as having measurements of 1.3mm ID x 3.4mm OD. I'd like to be able to use this cable, which describes its measurements as 1.35mm ID x 3.5mm OD x 18mm length. Is the latter likely to work with the PBP?
This says what you need;
https://wiki.pine64.org/wiki/Pinebook_Pro#Power_Supply
Arwen Evenstar
Princess of Rivendale
(03-25-2021, 04:03 PM)Arwen Wrote: This says what you need;
Thanks.
  Microphone in through headphone jack SageFox 1 6,937 03-26-2020, 12:27 PM
Last Post: zaius
