03-23-2021, 07:28 AM
https://xnux.eu/log/#031 the anx firmware can now be flashed on up to date 5.10 and 5.11 kernels
Fail safe way to update ANX7688 firmware
03-25-2021, 10:33 AM
(03-23-2021, 07:28 AM)Artturin Wrote: https://xnux.eu/log/#031 the anx firmware can now be flashed on up to date 5.10 and 5.11 kernelsHey Artturin, thanks for the hint... but these enhancements are only valid for megous kernel sources and the distributions using his kernel (e.g. Manajaro). Mobian people may have to wait a little bit i guess. Anyway it's great to see it getting fixed. Cheers, scholbert
03-26-2021, 09:05 AM
I've said it previously that I had zero issue with flashing on Mobian's kernel. I'm not sure where this claim comes from that flashing is not compatible with 5.10.
(03-26-2021, 09:05 AM)zborgerd Wrote: I've said it previously that I had zero issue with flashing on Mobian's kernel. I'm not sure where this claim comes from that flashing is not compatible with 5.10.Hey zborgerd, thanks for pointing this out again... i can't remember exactely, but i ran into trouble with my kernel version. That's why i started this thread Anyway, it's still a safe way to go using the test image, if someone's running into trouble. Cheers, scholbert
04-01-2021, 01:28 PM
(04-01-2021, 04:16 AM)scholbert Wrote:(03-26-2021, 09:05 AM)zborgerd Wrote: I've said it previously that I had zero issue with flashing on Mobian's kernel. I'm not sure where this claim comes from that flashing is not compatible with 5.10.Hey zborgerd, I know that Megi specifically has indicated that his kernel had the problem (via his blog), so that could be part of it. Maybe related to some patches. |
| firmware udate Quectel EG25-G modem | alwi | 7 | 14,916 |
07-06-2022, 01:43 PM Last Post: user641 |
| Need command to tell what modem firmware I am on. | purpletiger | 4 | 7,944 |
07-06-2022, 12:35 PM Last Post: Zebulon Walton |
| camera firmware problems | kqlnut | 25 | 41,450 |
09-02-2021, 07:49 PM Last Post: Zebulon Walton |
| 3/32 upgrade board, Arrived Without Firmware, Troubleshooting Steps to SOLVED | biketool | 0 | 3,144 |
06-22-2021, 10:03 AM Last Post: biketool |
| WIFI not available after anx7688 update failure | frimmel | 21 | 34,860 |
05-11-2021, 02:45 AM Last Post: frimmel |
| Pinephone mainboard v1.2 documentation update? | scholbert | 1 | 4,798 |
01-18-2021, 09:01 PM Last Post: bokomaru |
| New motherboard - ANX firmware won't flash. | --- | 17 | 25,210 |
12-26-2020, 01:53 PM Last Post: p1x3l3d |
| Update to 3GB/32GB mainboard not working | tlo | 2 | 6,476 |
11-09-2020, 04:40 PM Last Post: tlo |
| BraveHeart UbPorts Battery drain/Solder update | Vlodka | 2 | 6,773 |
10-04-2020, 11:18 PM Last Post: Vlodka |
