Run Mobian Unstable without risking being stuck without a working phone
If you follow the Mobian blog you may know there is an unstable branch now for those who want to test the cutting edge.
https://blog.mobian-project.org/posts/20...le-distro/
Some of you may be afraid to switch because you needs your phones to work and can't take the risk of something unstable upsetting that.
You can have your cake and eat it too. You can clone your drive via Balena Etcher onto an SD card or create an ISO image of it (back up) using Disks in Linux and burn it to an SD card. Even an encrypted drive. You should have a back up anyway. Use Jumpdrive on an SD to allow your computer to see the Emmc and don't decrypt it before cloning. Then you can use the SD card image for unstable and leave the Emmc alone. If things break you can just remove the SD card and still have a working phone in a pinch just by removing it. Make a change in the order of your favorite apps so you know what you are booted into. (exaple, put your phone on the left on the SD card image) The reason why is sometimes after an update on the Emmc your phone will only boot to the newer boot Image (the Emmc) but you can over ride that temporarily because some type of temporary FEL mode must be activated. Power and volume down will boot back into the SD card. Power and volume up will boot into the Emmc until the next update on the SD card. Then it will be normal boot priority with the SD card.
What's the verdict so far? Any differences from "stable"?
(03-15-2021, 04:09 PM)zborgerd Wrote: What's the verdict so far? Any differences from "stable"?
Phosh seems more fluid and responsive in the unstable. It's a newer version. The suspend/LTE data loss forcing a reboot got patched in the unstable the day before it made it to the stable. More apps to choose from in software but a lot don't work. Other then that I really haven't noticed anything else.
(03-15-2021, 09:58 AM)C0ffeeFreak Wrote: If you follow the Mobian blog you may know there is an unstable branch now for those who want to test the cutting edge.
Or if you have a Linux laptop/desktop, throw in a Jumpdrive sdcard and use lsblk/dmesg to find the emmc and dd to copy and even restore the backup.
Then run (from laptop hooked to Jumpdrive booted phone):
sudo dd if=/dev/EMMClocation of=Mobian-backup.img bs=12M status=progress
Then use Jumpdrive once again (reverse the if/of option values) to put right back on your emmc if something goes wrong Smile
- RTP
"In the beginner's mind there are many possibilities, in the expert's mind there are few." -Shunryu Suzuki
[ Pinephone Original | Pinetab v1 / v2 Enjoyer ]
Linux Device Privacy / Security Playlist
  Printing from Mobian johnd 3 5,297 10-27-2026, 06:01 AM
Last Post: PrinterSolvedTeam
  Mobian MMS/SMS text problem bcnaz 16 41,406 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 2,229 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 73,347 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 76,038 10-08-2025, 06:21 AM
  XLibre for Mobian Hiraghm 0 3,715 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 362,692 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 3,392 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 4,689 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 5,423 05-06-2025, 02:19 AM
