General use for USB-C docking bar
I've been trying to figure out how much I can use the docking bar which came with the Mobian CE Convergence edition. It worked under Mobian (I think) and pmOS (pretty sure - I'm spinning through distros to find what works). Doesn't work under Manjaro Plasma beta2.
I'm trying it out on my Manjaro Plasma laptop. syslog shows the components being recognized in it. Mostly works, but there's some oddities, like when I plug in the HDMI the ethernet shuts down. Is that something intentional in Manjaro Plasma? For example, I see when a second display is connected, Notification automatically switches to the do-not-disturb setting. Maybe it's shutting off the ethernet for some similar assumption about how it's being used?
It doesn't work very well at all on Windows 10 (same laptop - dual boot). Does it need a driver?
Is this docking bar a known device that has been labeled by Pine64? Does someone have the model of it so that I can search for drivers?
I also have a little GPD Pocket 1 mini-laptop. Docking bar doesn't work under Windows 10. I booted Manjaro Plasma on it and the docking bar doesn't work there.
In all cases, I power the docking bar with the power supply suitable to that computer.
Thanks for your insights.
Here is what my /var/log/messages shows when I plug it in on Debian:
[257326.913062] cdc_ether 5-1.1.2.4.2:2.0 enx00000000119e: unregister 'cdc_ether' usb-0000:2d:00.3-1.1.2.4.2, CDC Ethernet Device
[257338.497532] usb 5-1.1.2.4: new high-speed USB device number 14 using xhci_hcd
[257338.698598] usb 5-1.1.2.4: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.00
[257338.698600] usb 5-1.1.2.4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[257338.698601] usb 5-1.1.2.4: Product: USB2.0 HUB
[257338.752165] hub 5-1.1.2.4:1.0: USB hub found
[257338.752352] hub 5-1.1.2.4:1.0: 4 ports detected
[257339.137525] usb 5-1.1.2.4.1: new full-speed USB device number 15 using xhci_hcd
[257339.349118] usb 5-1.1.2.4.1: New USB device found, idVendor=0639, idProduct=7210, bcdDevice=68.4d
[257339.349120] usb 5-1.1.2.4.1: New USB device strings: Mfr=1, Product=4, SerialNumber=2
[257339.349121] usb 5-1.1.2.4.1: Product: Billboard
[257339.349122] usb 5-1.1.2.4.1: Manufacturer: Chrontel
[257339.349122] usb 5-1.1.2.4.1: SerialNumber: CH7210
[257341.833522] usb 5-1.1.2.4.2: new high-speed USB device number 16 using xhci_hcd
[257342.036263] usb 5-1.1.2.4.2: New USB device found, idVendor=0fe6, idProduct=9900, bcdDevice=20.00
[257342.036265] usb 5-1.1.2.4.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[257342.036266] usb 5-1.1.2.4.2: Product: 10/100M LAN
[257342.036266] usb 5-1.1.2.4.2: Manufacturer: CoreChips
[257342.036267] usb 5-1.1.2.4.2: SerialNumber: 00000000119E
[257342.081302] cdc_ether 5-1.1.2.4.2:2.0 eth0: register 'cdc_ether' at usb-0000:2d:00.3-1.1.2.4.2, CDC Ethernet Device, 00:00:00:00:11:9e
Sorry if this is equivalent to saying that water is wet Smile
  Convergence package USB-C Docking Bar for Wired Ethernet (part II) Peter Gamma 4 6,537 10-08-2023, 11:49 PM
Last Post: zetabeta
  None Pine64 USB-C Docking Bar? Peter Gamma 0 2,467 03-20-2023, 10:25 AM
Last Post: Peter Gamma
  PinePhone convergence docking bar malfunctioning bircoph 3 6,211 12-09-2022, 05:41 PM
Last Post: bircoph
  Convergence docking bar and keyboard pifou 4 8,518 06-23-2022, 04:40 AM
Last Post: wibble
  Docking Deck Question gesteves91 1 4,057 08-28-2021, 09:55 PM
Last Post: 33YN2
  New docking station murak 1 5,117 03-10-2021, 01:10 PM
Last Post: neil_swann80
  Convergence package USB-C Docking Bar for Wired Ethernet piney-tim 0 3,960 11-29-2020, 12:13 PM
Last Post: piney-tim
  Docking Station Zweitaktmotor 2 6,872 07-24-2020, 03:28 AM
Last Post: hiimtye
