Pine64 can run Ubuntu Server Arm, Ubuntu 15.10
I love Ubuntu. I research more more Pine64, but I not sure that pine64 can run Ubuntu Server for Arm, Ubuntu Mate, Ubuntu 15.04, 15.10, 16.04 (ubuntu core 15.04). If not, future can support?
(12-09-2015, 10:29 AM)minple Wrote: I love Ubuntu. I research more more Pine64, but I not sure that pine64 can run Ubuntu Server for Arm, Ubuntu Mate, Ubuntu 15.04, 15.10, 16.04 (ubuntu core 15.04). If not, future can support?
We are currently working on Ubuntu Snappy Core first. If anybody interest on accelerating Ubuntu porting, please let us know and we can provide free Pine64 board and Linux BSP. The currently Linux kernel is 64bit version 3.10, and will release version 3.18 and version 4.2 in 3months and 6 months time.
There is a development already explored in CentOS by other party and will takes few months to port.
Any future inclusion of OS X?
(12-09-2015, 03:51 PM)tllim Wrote: The currently Linux kernel is 64bit version 3.10, and will release version 3.18 and version 4.2 in 3months and 6 months time.
This release schedule is weird. You'll stay at 3.10 and as soon as you get support from the linux-sunxi community (don't expect that automatically) the hardware might be supported by mainline kernel sometimes in the future (kernel 4.x or even 5.x)
Hi Tllim,
I would like to try another linux kernel on this new Pine64. Smile
Thanks,
Prateek
(12-10-2015, 06:48 AM)Prateek Wrote: I would like to try another linux kernel on this new Pine64. Smile
You can't at the moment. If the Pine64 guys don't mess up with the linux-sunxi community there might be next year support in kernel 4.x or 5.x for the A64.
@tkaiser
You come out quite pushy. Do you represent the "linux-sunxi" community?
You make them appear as a vindictive mob.
Ubuntu-Core (14.04 and higher) is actually really easy to get running on most arm boards, usually its as simple as booting an existing kernel + modules with the ubuntu rootfs.
For example: on the Pi2, I can flash raspbian to a card, format the root partition, extract ubuntu-core into the now empty root, install modules from the raspbian image, and it generally works without modification. Granted it tends to be missing some parts such as GPU acceleration, but for my use cases (Servers/Headless) GPU really doesn't matter.
This trick also works on many other boards such as the Udoo Quad, and ODroid C1+.
Getting GPU accelerations is generally going to be the hardest part as some BSPs need to be matched and/or compiled for specific X versions. I had many acceleration issues on the Udoo and its IMX6 since those BSPs were horrid to work with, whereas Pi2 has been fairly easy.
Yes, it takes half an hour to provide a crappy Ubuntu image, we've told them already: http://forum.armbian.com/index.php/topic...-computer/
Thanks on the helpful tips.
  Programming languages support under PINE64 baryluk 6 20,091 09-23-2020, 11:46 PM
Last Post: Phillip Bell
  Manjaro arm on pine64+ roel 2 10,325 10-19-2019, 05:13 AM
Last Post: roel
  Volumio for PINE64 Released mikelangeloz 11 37,783 03-22-2019, 09:25 AM
Last Post: llungster
  I2S Audio patches for Pine64+ uploaded to GitHub ramstadt 1 6,453 01-19-2019, 11:31 AM
Last Post: ramstadt
  Pine64: Minimal SDL config Max11 3 9,787 01-04-2019, 03:47 PM
Last Post: Max11
  Fedora 27 on Pine64 gregjo 18 55,002 01-02-2019, 10:42 PM
Last Post: heatfanjohn
  Issues with both Deb and Ubuntu germanshep 0 4,307 08-28-2018, 05:47 PM
Last Post: germanshep
  Official build procedure of ayufan pine64 r.tanaka 0 4,850 08-21-2018, 10:54 PM
Last Post: r.tanaka
  DKMS on kernel 3.10.107-pine64 obrienmd 5 14,110 06-21-2018, 05:45 PM
Last Post: evilbunny
  need help, looking to setup NAS server over OpenWRT subbu 0 4,015 05-26-2018, 07:48 AM
Last Post: subbu
