APN setting for provider AldiTalk (Germany)
Question
Does anybody manged to get the PhinePhone working with the German Cellphone Provider AldiTalk or any other German carrier?
Hello.
Yes, this works well. Phone calls and data.
As you are used to on other phones, you should receive a configuration SMS.
This works for me with AldiTalk and Lidl Connect (Vodafone) on Mobian and Manjaro/Phosh.
AldiTalk is also working on SXMO (Lidl not tested).
Not quite sure, I think, I had problems with Ubuntu Touch and an other distri, I do not remember.
The SMS probably did not reach you. If so, you can enter the APN manually.
Name: Alditalk or E-Plus
APN: internet.eplus.de
User: eplus
Password: internet or gprs
Be aware, that the apn settings may vary, depending on your booked flat.
Consult your apn settings on your old phone
(02-10-2021, 12:11 PM)robbyk Wrote: Hello,
I bought a new AldiTalk sim card and initially it wouldn't connect to the network. After putting it in my android phone I received the configuration sms there and then it worked in my pinephone as well. Maybe that helps.
  USA - Faith Wireless a virtual AT&T provider just kicked my PinePhone off... mikehenson 1 3,460 02-07-2022, 07:43 PM
  VoLTE calls with o2 (Germany) arno_nuehm 6 16,344 07-06-2021, 02:38 AM
Last Post: arno_nuehm
  pinephone in germany (telefonica) ? robotnik 2 6,646 01-18-2021, 07:14 AM
Last Post: InternetQuatsch
  PinePhone for sale - Germany (no longer for sale) aus 0 3,144 12-15-2020, 12:58 PM
Last Post: aus
  Germany batch will be delayed vicky 80 161,264 10-01-2020, 12:23 AM
