gnome-contacts not showing call nor sms button
I am encountering a issue with gnome-contacts.
Whenever I open a contact, there is no button showing next to the phone numbers, for calls or sms.
Next to the email addresses, I can see the button for sending an email (which works OK and open geary), but no buttons are showing next the the phone numbers.
I checked in /usr/share/applications/gnome-mimeapps.list, which did not have any
x-scheme-handler/tel x-scheme-handler/sms
lines, so I added these lines :
x-scheme-handler/tel=sm.puri.Calls.desktop x-scheme-handler/sms=sm.puri.Chatty.desktop
but still no luck after that.
Any suggestion ?
Mine just work - I did originally import my contacts via Evolution but probably irrelevant.
Can you manually dial numbers?
Are your numbers properly stored as MSISDN (i.e. including CC with a + prefix)?
Yes, dialing directly from Calls is OK.
As for the numbers, I have all kind of formats, including proper MSISDN with "+", and the buttons are showing for none of them.
It used to work, and probably got broken after an upgrade/dist-upgrade, but since I don't use the functionnality that much, I don't know exactly when it occured.
  troubleshooting sleep/wake button on trixie biketool 5 5,093 05-04-2025, 08:11 PM
  New camera app gnome-snapshot working on trixie? vusra 4 5,111 04-11-2025, 02:53 AM
Last Post: vusra
  Modem wakes for incoming call, but too slow to answer the call dchang0 8 6,684 12-01-2024, 07:54 PM
Last Post: dchang0
  Proximity sensor is oversensitive (was "Screen blanks when making call") treebeard 6 10,735 08-05-2024, 06:12 AM
Last Post: baptx
  gnome-control-center: segmentation fault on startup jojuma 4 6,102 09-12-2023, 08:49 AM
Last Post: jojuma
  Nextcloud Calendar and Contacts mark1250 3 5,082 12-29-2022, 07:27 PM
Last Post: mark1250
  Dist-upgrade and Chatty vs Gnome-Contacts biketool 9 12,039 09-30-2022, 08:53 PM
Last Post: treebeard
  Pinephone incoming call / SMS notification no ringing / notification volume dcinoz 3 7,581 06-02-2022, 07:16 AM
Last Post: arkadione
  Vibration motor buzzes uncontrollably with call waiting Zebulon Walton 2 4,503 05-28-2022, 07:32 PM
  Gnome Web CSS problem? jojuma 0 2,163 05-27-2022, 11:43 AM
Last Post: jojuma
