Cannot boot from SDCard
about 2 months ago (I think) an update broke my postmarket installation resulting in an endless boot loop (booting - entering encryption password - crashing and rebooting). Now I finally found the time to try and fix it, so I tried flashing the latest version to a SDcard (tried pmbootstrap before that as well) and boot from there. But my phone keeps booting from the internal storage.
Any hints as to why it's not working? Is there anything I'm missing?
(I am pretty sure I am using the correct slot, since I use the phone with a SIM card.)
Help would be much appreciated!
If it's booting from the internal storage it's not finding, or running into problems trying to run, the bootloader on the SD (or, less likely, that the bootloader on the SD is configured to boot the OS on the eMMC.) That probably means it wasn't written properly, but it could be a problem with the downloaded image, or even the SD card.
(01-30-2021, 11:34 AM)wibble Wrote: If it's booting from the internal storage it's not finding, or running into problems trying to run, the bootloader on the SD (or, less likely, that the bootloader on the SD is configured to boot the OS on the eMMC.) That probably means it wasn't written properly, but it could be a problem with the downloaded image, or even the SD card.
You're right, it was an issue with the bootloader. Thank you very much!
  Fresh install pmos+phosh does not boot user641 1 3,701 10-08-2023, 04:04 AM
Last Post: user641
  Disable mobile data auto-enable on boot 64_Tesseract 3 6,213 08-11-2022, 02:48 AM
Last Post: 64_Tesseract
  phone won't boot from emmc with sdcard inserted ssilvi 3 7,593 06-06-2021, 02:47 AM
Last Post: ssilvi
Information pmOS CE phone cannot boot from known good SD singpolyma 2 7,652 09-05-2020, 06:36 PM
Last Post: juanjoseor
  unable to boot the phone with PM OS after battery has completely discharged nieral 1 5,393 08-24-2020, 06:34 AM
Last Post: PureTryOut
  How to update U-Boot for PostmarketOS on the PinePhone and much more! dustfinger 2 7,807 08-21-2020, 10:49 AM
Last Post: bingo600
  PostmarketOS won't boot lapinus 0 3,715 07-22-2020, 07:25 AM
Last Post: lapinus
  pmaports root & boot mount issue dustfinger 0 3,323 07-07-2020, 09:43 AM
Last Post: dustfinger
  pmbootstrap to sdcard Jeb5Blovrueb 34 79,425 07-07-2020, 04:17 AM
Last Post: fernando_c_m
  Bug: When you initially boot it does not bring up the password screen realrichardsharpe@gmail.com 5 11,718 02-12-2020, 11:58 PM
Last Post: pjsf
