Updating issue
I'm currently unable to update my Postmarket OS pinephone.
Error message that comes up is "unable to download updates from "odrs.gnome.org":
failed to download https://odrs.gnome.org/-1.0/reviews/api/ratings: SSL Handshake failed
Any advice here?
Is the system time on your phone correct? I don't get an ssl error and the certificate should be valid until march
System time is correct...
Is there an easy way to reset any of this?
That error is only to download application ratings, which you really don't need to upgrade.
Try "apk upgrade -a" in a terminal and see if that works.
Thanks!
I tried "apk upgrade -a,
received the following;
"Unable to lock database: Permission denied
Error: failed to open apk database: Permission denied"
apk upgrade -a -s yields;
"failed to open apk database: Permission denied
Error: unsatisfiable constraints:
Provided by: imagemagick
required by: megapixels-0.13.1-r0[cmd:convert]
I am a total noob here, but does this indicate the megapixels app is causing an issue?
Any further steps I can take?
Edit;
Was able to update after deleting megapixels.
Weird.
  Plasma mobile latest stable @pp1.2b voice calling audio issue n05ph3r42 3 5,428 10-03-2023, 06:32 PM
  Pinephone 64 PostMarketOS edition Battery Issues, Not Hardware Issue X0X0X0X0X0 1 4,663 02-11-2023, 08:19 AM
Last Post: acid andy
  Error when updating syrinx 1 4,060 03-06-2021, 01:32 AM
Last Post: hiimtye
  megapixels issue spartacus 4 8,457 03-04-2021, 10:08 AM
Last Post: hiimtye
  pmaports root & boot mount issue dustfinger 0 3,240 07-07-2020, 09:43 AM
Last Post: dustfinger
