SSH for noobs on Debian
Check your router ip table to see what ip your pine64 is using after the update.
(05-06-2016, 06:41 AM)Luke Wrote: Yes, I dont think that root comes with a password; the default user (pine64user) is a sudoer
[edit: but did you try to connect as pine64user ---- ssh pine64user@you-ip-address ?  --- didnt you get a password prompt ?
I am using PuTTY so it doesn't prompt you for the username until the connection is made, and as I've said before the PINE64 was actively refusing connections so there was no login prompt (username or password).
(05-06-2016, 07:04 AM)rahlquist Wrote: KuJoe,
Are you sure you are using the right IP? I ask because the pine, with each new OS install, gets a new MAC. So DHCP would issue a new IP.
For me when I was first getting debian going my DHCP handed out about 12 IP's as I was having to reinstall often due to flash issues.
Yes, 100% positive. This was the first time I've powered on the PINE64 and so I was logged into the router and saw the IP it was assigned and then I made a static entry for the PINE64. Rebooted it multiple times and could ping it each time.
(05-06-2016, 10:28 AM)Luke Wrote: yea, this too. You may be connecting to a previous IP
Since this was the first time I powered the device on there was no previous IP unfortunately. Sad
(05-06-2016, 07:00 PM)Leoncito81 Wrote: Check your router ip table to see what ip your pine64 is using after the update.
What update? There hasn't been any changes to my PINE64.
Try installing MinGW. (www.mingw.org). It will give you a minimal Linux shell to be able to control the pine64.
Then you can use SSH through the Linux shell. It will prompt you.
  Arch, Debian or other for Pinebook? cootcraig 3 11,648 05-01-2019, 09:11 AM
Last Post: cootcraig
  Pine64 will be supported by HypriotOS (a Debian Jessie based OS for running Docker) Quintus23M 9 26,065 02-03-2017, 05:50 AM
Last Post: pfeerick
  Netatalk on Debian pictus 10 22,282 09-28-2016, 08:01 AM
Last Post: wojciech_czyz
  How to make multicast working on ubuntu and debian brengthdom 3 10,671 09-18-2016, 02:05 PM
Last Post: brengthdom
Lightbulb Debian (Raspbian-like) Pander 15 34,380 04-09-2016, 08:40 PM
Last Post: lenny.raposo-pine64.pro
  Minimal 64bit ARM RootFS for Debian and Ubuntu umiddelb 46 108,210 03-06-2016, 10:28 AM
Last Post: umiddelb
  1st Debian image and further information umiddelb 13 32,678 03-04-2016, 02:08 AM
Last Post: umiddelb
