Pinephone back plate / case idea for switches
Question
I am interested in purchasing a pinephone but the one thing holding me back is the dip switch location.
My idea at first was to cut out the back place to have easier access but the switches are tiny, so I cam up with a newer idea.
Why not make a back plate or case that not only allows access to the kill switches, but also enlarges them so it is more practical and convenient? Yes of course the back would stick out more but it is something we could get used to by necessity?
Maybe this is easier said then done but I would love to have this option. Thoughts?
I have been thinking about something similar. I think one problem might be that the switches are really close to each other. I still don't think this would be impossible. If I had a 3d printer I would try making this.
(01-10-2021, 02:04 AM)bartaco Wrote: I am interested in purchasing a pinephone but the one thing holding me back is the dip switch location.
What if you accidentally glide over the switches while the phone is in your pocket?(白目)
母語は日本語ですが、英語も喋れます(ry
I'd be happy with a back cover that has a window that opens to expose the switches, with a tool attached to the inside of the window for use on the switches.
OR
Perhaps a single switch that slides side to side over the dip switches, clicking into place above each switch; the switch can be pushed up and down, springs return it to center. A locking mechanism to prevent pocket activations.
I would be worried about dust and pocket lint. I have never had an issue taking off a cell phone case, obviously the small switches are less than Ideal, but at least you have options for set up!
I like this idea a lot.  Maybe a little door that either slides to reveal the switches or hinges and snaps.
  Pinephone (Pro) Keyboard Case for sale manubert 8 19,276 05-15-2026, 11:36 AM
Last Post: oliveira11670
  NEW pinephone keyboard case and LoRa backplate for sale ragele 0 3,010 01-12-2026, 06:09 PM
Last Post: ragele
  Replacement battery for PinePhone? j_s 9 10,759 06-03-2025, 04:19 PM
Last Post: j_s
  keyboard case charging but not typing new2pinephone 19 27,085 02-14-2025, 04:09 PM
Last Post: zltpxqhp69o2
  Searching for a PinePhone Keyboard Case RubiksCube 1 5,454 10-07-2024, 11:08 PM
  Troubleshooting Pinedio LoRa Add-on Case nickp 2 4,482 09-29-2024, 09:17 PM
Last Post: lavabrilliant
  Getting started with fingerprint scanner case lolgzs 1 5,577 09-08-2024, 04:21 AM
Last Post: mfashby
  So which keyboard you suggest for the Pinephone? Peter Gamma 21 23,336 07-19-2024, 08:05 AM
Last Post: Peter Gamma
  Keyboards for the PinePhone? Peter Gamma 1 5,419 07-04-2024, 10:22 PM
  Bring the Pinephone keyboard back, it is worth it! Peter Gamma 1 5,285 07-04-2024, 07:32 AM
