01-13-2021, 03:45 AM
Announcing the Mobian project
01-13-2021, 04:19 AM
(01-13-2021, 03:45 AM)fdlamotte Wrote:(01-13-2021, 02:47 AM)dcinoz Wrote: I'm not sure why uname -r doesn't include the .6 but from apt list I understand I'm actually running 5.10.6, right? @fdlamotte Thanks, downloaded from https://repo.mobian-project.org/pool/mai...0-sunxi64/ and installed using sudo dpkg -i . Rebooted and suspend works again!
01-14-2021, 08:16 AM
since last update i have heavy flickering, but at least the problem with that wierd blue LED and always-on-display seems to be fixed
i noticed when i plug in the device to my pc to load it, it is recognized as usb ethernet device - guess thats not how its supposed to be thought i uninstall now anbox (as i dont want to install whatsapp anymore) and after opening the terminal, the complete phone crashed
01-20-2021, 06:12 PM
Pre-Ordered the Mobian edition of the PinePhone and am very excited to finally get this device and review it for my blog
librefree.me
02-16-2021, 08:51 PM
I noticed the vanishing modem issue recently - issue on https://gitlab.com/mobian1/issues/-/issues/251
I've lodged one for the much higher battery drain recently, still seems high, but had drained the battery in a few hours with only modem on: https://gitlab.com/mobian1/issues/-/issues/252 Modem seems to come back on when I check phone but I think battery drain is still higher than it was.
02-18-2021, 06:02 AM
I'm not sure what happened with the high battery drain I experienced a few times.
I tested an up-to-date Mobian today and the news is very good with very low battery use with suspend mode: Mobile on 4G, no data, no BT, no Wifi. Phone is in suspend mode via systemctl suspend command. Time Battery 0900 100% 1000 97% ( -3% +1h) 1100 95% ( -5% +2h) 1200 94% ( -6% +3h) 1300 93% ( -7% +4h) Turned Wifi on 1303, can ping when on, no more pings when suspend via systemctl suspend. As a test if leaving Wifi on might have caused excess drain during sleep - no! 1400 92% ( -8% +5h) 1500 91% ( -9% +6h) 1600 90% (-10% +7h) 1700 88% (-12% +8h) 1800 87% (-13% +9h) 1900 85% (-15% +10h) 2000 82% (-18% +11h) 2100 79% (-21% +12h) 2200 77% (-23% +13h) udev rule and usb settings as per https://gitlab.com/mobian1/devices/eg25-...ts/5/diffs No idea if they make a difference but seems to be recommended by Quectel. This is a passive mode phone in standby with phone always in suspend (sleep) mode. Still excellent! Guess I can eat my words on high battery drain though I did not make it up and it happened both during the day and overnight (phone in airplane mode overnight, too). On another note, I saw linux-image-5.11-sunxi64 was there and installed it, but upon reboot I never got the login / unlock screen.
02-21-2021, 08:31 PM
Nice improvement for eg25-manager with user configurable file e.g. see https://forum.pine64.org/showthread.php?...9#pid90279
I've installed Manjaro Plasma Mobile on EMMC given the Pine64 announcement. Running kernel 5.10.17-1, impressed by incoming calls - an incoming call pops up on the screen (even in suspend) *before* I hear the ringing tone on the calling side! I use Code: systemctl suspendNote I had to update as incoming calls just woke up the screen and did nothing. Mobian still is typically 11s (though the first attempt it took a lot longer, strange). This gives me hope Mobian can benefit from what Manjaro Plasma Mobile have done on the modem / phone resume side. I'm curious as to the incoming SMS notification issue - not always happening with Mobian - wonder how well Manjaro Plasma Mobile are doing.
03-01-2021, 08:17 PM
(02-18-2021, 06:02 AM)dcinoz Wrote: On another note, I saw linux-image-5.11-sunxi64 was there and installed it, but upon reboot I never got the login / unlock screen.Figured out the problem as have the same problem with Manjaro Plasma Mobile (screen brightness is set too low at least for my v1.2) https://forum.pine64.org/showthread.php?...5#pid90815
03-03-2021, 12:02 AM
(05-14-2020, 09:46 AM)a-wai Wrote: Dear all,
03-03-2021, 12:04 AM
(05-14-2020, 09:46 AM)a-wai Wrote: Dear all, |
| Printing from Mobian | johnd | 3 | 5,107 |
10-27-2026, 06:01 AM Last Post: PrinterSolvedTeam |
| Mobian MMS/SMS text problem | bcnaz | 16 | 41,035 |
06-23-2026, 06:53 AM Last Post: mehdy |
| Mobian image for the PinePhone | Korfou | 2 | 2,095 |
04-27-2026, 09:57 AM Last Post: Korfou |
| bookworm vs trixie discussion for mobian in pinephone regular. | zetabeta | 80 | 71,718 |
12-24-2025, 12:11 AM Last Post: Kevin Kofler |
| cryptocurrency on mobian/pinephone | biketool | 33 | 75,296 |
10-08-2025, 06:21 AM Last Post: biketool |
| XLibre for Mobian | Hiraghm | 0 | 3,613 |
06-29-2025, 12:38 PM Last Post: Hiraghm |
| Axolotl on PinePhone / Mobian | arno_nuehm | 223 | 357,662 |
06-25-2025, 01:19 PM Last Post: anonymous |
| VoIP account on mobian dialer | j_s | 0 | 3,292 |
06-15-2025, 04:19 PM Last Post: j_s |
| Mobian Pinephone Notification LED | biketool | 2 | 4,553 |
06-07-2025, 03:19 PM Last Post: KC9UDX |
| Vivaldi Web browser nearly native for Mobian | biketool | 3 | 5,293 |
05-06-2025, 02:19 AM Last Post: biketool |
