Compile kernel 3.10 failed
Hi, i'm trying to compile the kernel 3.10 and i have the error: ERROR: build buildroot Failed
I downloaded this file from wiki: http://files.pine64.org/os/sdk/A64-ver2....SP-2.0.zip
Someone can help me?
It was an error with the file permissions . Now I got the following error
http://pastebin.com/SefcbyKs
check out @longsleep's kernel threads. It took some effort to take the BSP kernel & get it up and running. Check out his repo and try to re-use his kernel sources rather than going with the code from BSP.
BSP 2.0 had really nothing to offer hence why it hasn't been used.
If you like my work be sure to check out my site or wish to donate to the cause
Cheers Big Grin
Okay, I'll try to Longsleep kernel . Thank you all
One more thing, you would have documents that might help me understand more about kernel modification, add drivers?
look here
https://github.com/longsleep/build-pine64-image
there is a nice step by step
not to mention the scripts that everyone should contribute to Wink
Cheers Big Grin
I'm going home now and try to compile
Thank you
The script error says you lack gcc. Have you installed gcc, g++, or another compiler to make the kernel?
I would like to thank everyone for the help. I spent those days reading and learning how to do this by following the links you gave me and finally got. They were of great help. I have a lot to learn yet, but it's a start.
Thanks also to Longsleep for all the hard work and the scripts that are helping me a lot
Sorry for bad english
  PineA64+: Audio in 5.0 Kernel puzzles 6 16,752 11-13-2019, 09:41 AM
Last Post: roel
  Rockpro64 NFS root mount (kernel 4.20) - ethernet help? tenspd137 0 4,947 12-06-2018, 01:14 AM
Last Post: tenspd137
  NVMe and new kernel bjbb17 0 4,409 09-25-2018, 03:39 PM
Last Post: bjbb17
  Real-time linux kernel Artyom 45 124,959 09-11-2018, 01:08 AM
Last Post: zzwpine
  DKMS on kernel 3.10.107-pine64 obrienmd 5 14,592 06-21-2018, 05:45 PM
Last Post: evilbunny
  Kernel for A64 git longsleep 179 437,347 03-25-2018, 03:25 PM
Last Post: Luke
  Gentoo for pine64 - longsleep kernel incoherent 0 5,677 12-09-2017, 08:14 AM
Last Post: incoherent
  +PINEBOOK: Newbie Trying to Compile RStudio On Pinebook MiningBrutus 3 9,709 08-12-2017, 04:55 PM
Last Post: MarkHaysHarris777
  [SOLVED] UEFI + Fedora Mainline Kernel Booting! cztian 0 5,189 07-13-2017, 08:38 PM
Last Post: cztian
  How to compile on other systems for Pine utdrmac 3 9,483 03-08-2017, 02:40 PM
Last Post: xalius
