Pinecil - Tip Disconnected
Hi all!
I just received my Pinecil today, and was keen to try it out. However, the tip does not heat up, and before calibration the display showed a very high temperature readout (420+ degrees C) while the iron remained at room temperature.
Enabling "Advanced Options" => "Detailed Idle Screen" reveals that the tip is not detected by the Pinecil. The message "TIP DISCONNECTED" persists, regardless of which tip I insert, and the status of the locking screw.
I have not tried to use the grounding connection as yet, and my power sources tested so far have all been USB-C PD.
This issue persists upon updating to the latest release of the firmware, using the provided firmware flashing documentation.
I believe this may be a hardware issue or user error, hence my post here. Has anyone else experienced a similar issue with their Pinecil?
(12-30-2020, 10:38 PM)molzy Wrote: I believe this may be a hardware issue or user error, hence my post here. Has anyone else experienced a similar issue with their Pinecil?
I haven't had similar issues with Pinecil.
It showed correct temperature values from the beginning (so starting from around room temperature).
I only receive "TIP DISCONNECTED" message if I disconnect the tip.
I have a feeling you may have some soldering problem inside, so it may not have connection of temperature signal pin for example.
(01-02-2021, 04:54 AM)VaZso Wrote: I have a feeling you may have some soldering problem inside, so it may not have connection of temperature signal pin for example.
Thanks VaZso!
I opened the unit and quickly found a dodgy looking connection of a resistor (R2), which doesn't appear to be anywhere near the tip detection according to the schematic. It's for grounding after a power regulator associated with the USB-C VBUS. The rest of the components have been populated, and I can't find any other obvious soldering imperfections.
I'll repair that connection and give the unit another pass when I next have time, and if I don't find anything else, I'll open a warranty case to see what I can find out.
  Pinecil as a Pocket-Sized Wingman? Arsen 0 295 08-27-2026, 09:15 AM
Last Post: Arsen
  Question about firmware updates on Pinecil V2 helengrace 1 2,420 10-16-2025, 10:41 PM
  incorporate a multimeter into the Pinecil kellanphil 2 4,305 08-13-2025, 01:14 AM
Last Post: lalisa12
Lightbulb Pinecil -> Pinegun? Avamander 21 41,593 01-21-2025, 01:09 PM
  Will the Pinecil work for repairing iPods, in particular the 30pin port connector? drewdavis 0 1,821 08-27-2024, 08:01 PM
Last Post: drewdavis
Exclamation What is this - Pinecil V3? andrea6 2 16,966 12-19-2022, 08:11 PM
  on pinepower, pinecil stopped working.. sanderboer 1 3,541 09-23-2022, 03:47 AM
  Just got my Pinecil donwynne 1 3,695 04-22-2022, 07:01 AM
Last Post: bbeeast
  Pinecil Broken? skaaq 4 11,236 01-25-2021, 11:28 AM
Last Post: skaaq
  Pinecil stuck in shipping? mbreese 3 8,494 01-07-2021, 07:46 AM
Last Post: moxx
