Accelerated H.264 and HEVC video decoding with Cedrus
#31
(05-05-2016, 04:52 PM)longsleep Wrote: Sorry the binary package is named libvdpau-sunxi1 (note the 1 at the end).
Thanks longsleep, that work Smile
#32
I am using Ubuntu and I have installed libcedrus, libump,  libvdpau-sunxi and xserver-xorg-video-fbturbo from the PPA of longsleep, but I can't play videos using the default video player. Even watching a YouTube video at 240p is a bit laggy. Did I make a mistake? What should I do to enable hardware acceleration?
#33
Use mplayer via script in /usr/local/sbin
#34
(05-09-2016, 11:08 PM)longsleep Wrote: Use mplayer via script in /usr/local/sbin
I tried to launch the script, but it says it can't find mplayer. What should I do? Thanks for help
#35
Install it? http://lmgtfy.com/?q=install+mplayer+ubuntu
#36
Yeah, it works. I hope that in future, more codec will be supported and MPlayer will work even not from the shell
[Image: a52c3f3a03d30a4972a905bc8caca9a0.jpg]
#37
Use SMPlayer for a nice GUI.
#38
(05-10-2016, 01:56 PM)ssvb Wrote: Use SMPlayer for a nice GUI.
Thanks to all for help. I am a Linux noob, but I am learning fast [WINKING FACE]
#39
You should probably update the mplayer wrapper script as you do not have audio. https://github.com/longsleep/build-pine6...er-play.sh
#40
Sorry but I can't find the Cedrus build instructions on http://linux-sunxi.org/Cedrus What am I missing?
  Video wall? monty1 2 7,781 04-12-2017, 04:34 PM
Last Post: monty1
  pine64 accelerated jpeg decoding jacklau 1 6,450 01-12-2017, 01:12 AM
Last Post: Trizna
  Pine64 accelerated H.264 encoding hngjms 7 19,743 10-18-2016, 03:15 AM
Last Post: pfeerick
  The sunxi transform module is very slow, how to do video rotation? jacklau 0 4,016 09-19-2016, 12:24 AM
Last Post: jacklau
  Video encoding h.265/HEVC tomaThoma 1 8,702 07-02-2016, 11:35 PM
  Question about video acceleration BringItOn 10 24,504 06-23-2016, 10:33 AM
Last Post: ssvb
  Linux accelerated graphics nomadewolf 1 6,761 12-29-2015, 11:26 PM
