Raspberry Pi 7" Touchscreen Display not work?
Bug
Hi
Is it possible, that i can't use the RasPi 7" Touchscreen? Huh It seems that the ribbon cable is a millimeter too wide...
Has someone already made to work?
Paara
(05-05-2016, 08:17 AM)Paara Wrote: Hi
Paara
You are using DSI connector correct? OOPS misread thought you were trying to connect the Pine screen to the Pine. Yeah thats not going to work.
Paara
It is not possible as is, very LCD panel need be to customize. However, if you know how to make a flex cable converter, it may work. Another issue is the RPi LCD screen resolution is lower than Pine A64 one and this also need to adjust. Too many works.
  What other devices can the LCD screen work on? kodachrome 1 5,373 12-07-2019, 06:50 PM
Last Post: kodachrome
  Search Compatible 10.1" touchscreen alfredo78 0 3,621 07-06-2018, 03:48 AM
Last Post: alfredo78
  Larger LCD touchscreen stephen fleming 3 7,823 06-13-2017, 03:16 AM
Last Post: mbt28
  Armbian display manager issues modsbyus 0 4,588 02-08-2017, 06:18 PM
Last Post: modsbyus
  8inch display compatible to FY07024DI26A30-D mbt28 0 3,742 01-26-2017, 10:07 AM
Last Post: mbt28
  lcd and hdmi dual display jodybrown99 8 18,665 11-12-2016, 08:07 PM
Last Post: Chisel_86
  Touchscreen display mods atomicSoC 2 10,350 08-26-2016, 05:44 PM
Last Post: pfeerick
  LCD Panel Connected but does not work maipercaso 1 4,974 08-20-2016, 08:14 PM
Last Post: MarkHaysHarris777
  Trouble with LCD display jdmwrx94 3 8,126 07-25-2016, 12:21 PM
  Touchscreen support? NoahJ 12 25,443 07-09-2016, 12:01 PM
Last Post: yodermk
