Compatible bluetooth headsets?
I paired my Samsung HM1350 headset to my Pinephone but all I get is static sounds out of it. The Samsung headset works fine with my old flip phone. Are there any bluetooth headsets that are known to work with the Pinephone? (It's the Manjaro convergence edition phone running the latest Mobian.)
I played music through a very old Jabra BT3030 some time back, but didn't try it for calls. I wouldn't recommend it though - things have moved on a long way even if you can find one anywhere.
(12-02-2020, 08:39 PM)wibble Wrote: I played music through a very old Jabra BT3030 some time back, but didn't try it for calls. I wouldn't recommend it though - things have moved on a long way even if you can find one anywhere.
It'll be interesting to try it with the bluetooth in the car. (That vehicle is way too old to have built-in bluetooth but I have an adapter for the radio that's known to work with my flip phone.)
  Kill switches for Wifi/Bluetooth does not work luxgiammi 0 2,907 10-14-2024, 03:34 PM
Last Post: luxgiammi
  bluetooth wifi bugs aular 6 7,185 08-27-2023, 07:53 AM
Last Post: aular
Question bluetooth speakers and pinephone pro Supervisor 2 4,000 01-30-2023, 09:21 AM
Last Post: Supervisor
  No wifi/bluetooth on multiple OS's Xxancap15 1 3,407 10-28-2022, 12:10 PM
Last Post: fxc
  Wifi no scan results - Bluetooth adapter not available emsyr 1 3,882 08-29-2022, 02:46 PM
Last Post: emsyr
  Is the PinePhone compatible with UHS-II or UHS-I Micro SD? 5432h90asfd 5 11,453 09-20-2020, 03:19 PM
Last Post: bitnick
  2.4 GHz WiFi bandwidth reduced 50% when Bluetooth enabled jrobin28260 0 3,131 07-22-2020, 10:05 AM
Last Post: jrobin28260
