Installing applicatons via command line
I'm finding that with the Mobian "Software" application, any category selected causes the program to abort. If I install a graphical program from the command line with apt or apt-get, will it appear as an app on the Pinephone screen? If not, what would I have to do to create a screen icon for it? (Going in on the command line there are no .desktop files in the Desktop directory as would be seen in a standard-issue Debian system.)
The 'Software' application has been notably buggy - probably best to ignore it unless you want to test it. Installing via apt will have the same result that 'Software' would if it worked. If the packages supplies the .desktop file in one of the globally expected places it will appear. I think the usual one is /usr/share/applications/
Thanks, just installed linssid via apt and the icon appeared on the Pinephone screen. (Unfortunately it doesn't work. When launched from the command line it says it cannot connect to display :0. Maybe not compatible with Wayland yet.)
Actually it may not be a Wayland issue. The cascade of error messages that come up indicates a possible Qt plugin configuration problem. (Searching online reveals other applications with similar problems.) I was hoping to be able to use the pinephone to do wifi surveys (at least for 2.4GHz). It looks like for now "nmcli d wifi" run from the command line will have to do.
  Command to test vibration motor? Zebulon Walton 3 6,012 11-12-2023, 08:45 PM
Last Post: zetabeta
  Block firefix-esr-mobile-config from (re)installing itself grump_fiddle_reinstall 3 5,444 01-07-2023, 09:36 AM
Last Post: dcarvil
  ARM Microsoft Teams-problems installing eaglebeckley 15 27,720 01-14-2022, 01:59 AM
Last Post: Tazdevl
  How to Make Mobian Boot to Command Line Ubermunchen 4 8,196 11-02-2021, 08:34 AM
Last Post: ryo
  Installing Mobian --> "Resizing file system" forever Anna 13 25,145 09-09-2021, 04:26 AM
Last Post: spaetz
  Is there a way to do gnome-authenticator via the command line? motox6 0 2,635 05-06-2021, 10:41 PM
Last Post: motox6
  Installing and tweaking Chromium on Mobian and Arch C0ffeeFreak 19 35,875 03-11-2021, 09:24 AM
Last Post: C0ffeeFreak
  "Low Disk Space on Filesystem root" after installing Axolotl and Podcasts Anna 11 18,662 03-05-2021, 02:33 AM
Last Post: Anna
  Installing chromium browser? Zebulon Walton 12 31,131 02-09-2021, 12:33 PM
  installing vpn ergo owl 3 7,154 10-02-2020, 04:22 PM
Last Post: ergo owl
