11-30-2020, 09:02 AM
Is there a way to do that with mobian? Or at least from vcf files.
how to import contacts from sim cards
11-30-2020, 10:11 AM
you should get familiar with documentation of mobian and search function in this forum ^^. Nevertheless I've written this:
https://forum.pine64.org/showthread.php?...4#pid84184 which is a workaround how to fix a known problem but also lists the link to the mobian docu how to import the vcf
11-30-2020, 04:21 PM
(11-30-2020, 09:02 AM)cybercow Wrote: Is there a way to do that with mobian? Or at least from vcf files. My solution was to install Evolution on my computer and import all VCF files. My old mobile makes many VCF file for one contact, so when the importation was done, I delete the unnecessary contacts. Because I've never used Evolution before, the configuration is fresh for the contacts. All contacts are stored in a file, this file must be push on the Pinephone. For me, the Contact's file is : ~/.local/share/evolution/addressbook/system/contacts.db Copy the file to : /home/mobian/.local/share/evolution/addressbook/system/contacts.db (11-30-2020, 04:21 PM)Gribouille Wrote:(11-30-2020, 09:02 AM)cybercow Wrote: Is there a way to do that with mobian? Or at least from vcf files. Thanks, this worked great! I found that it was possible to export the contacts in my flip phone to a vcf file via bluetooth to my Linux desktop, so after doing that I installed Evolution, imported the vcf file, copied as you indicated, rebooted the Pinephone and all my contacts are there!
12-02-2020, 10:59 AM
Seams like the evolution version actually in the mobian repo is pretty much incompatible with every file produced by the Phone i reactivated for the workaround and also the evolution actually in debian stable
Or it is me just having a broken install of evolution . . .
12-02-2020, 12:28 PM
I had 0 problems while following the documentation. Can you describe your problem in more details?
12-02-2020, 04:19 PM
(12-02-2020, 10:59 AM)cybercow Wrote: Seams like the evolution version actually in the mobian repo is pretty much incompatible with every file produced by the Phone i reactivated for the workaround and also the evolution actually in debian stable Probably just you with a broken evolution. I also had no problems following that procedure.
12-06-2020, 01:14 PM
(12-02-2020, 04:19 PM)dcarvil Wrote:lol seams like the copying process preserfed owner und rights of the files so i had to do(12-02-2020, 10:59 AM)cybercow Wrote: Seams like the evolution version actually in the mobian repo is pretty much incompatible with every file produced by the Phone i reactivated for the workaround and also the evolution actually in debian stable Code: chmode mobian <filename/> |
| Nextcloud Calendar and Contacts | mark1250 | 3 | 5,064 |
12-29-2022, 07:27 PM Last Post: mark1250 |
| Dist-upgrade and Chatty vs Gnome-Contacts | biketool | 9 | 12,007 |
09-30-2022, 08:53 PM Last Post: treebeard |
| Add contacts with VCF files | Bouc | 12 | 27,938 |
05-20-2022, 07:26 AM Last Post: kebab |
| Deleting telephone contacts | Emilio | 4 | 6,608 |
02-18-2022, 05:43 PM Last Post: Zebulon Walton |
| Synchronizing: How do you sync / synchronize Calendar and Contacts with your desktop? | Anna | 15 | 27,611 |
11-04-2021, 03:54 AM Last Post: Maus |
| gnome-contacts not showing call nor sms button | cafe | 2 | 5,366 |
02-11-2021, 01:31 AM Last Post: cafe |
